Author Topic: oil level sensor  (Read 3819 times)
Offline pd9264
oil level sensor
« on: December 06, 2015, 03:40:16 pm »
Checked my oil level the other day and it was just on the tip of the dipstick. Surely the oil level sensor should of poped up on the dash. Do you reckon it could be a faulty sensor or was the oil not low enough yet
Anyway put a litre of oil in and its up to max now.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
Re: oil level sensor
« Reply #1 on: December 06, 2015, 03:57:28 pm »
Many cars on the market don't show low oil until it's literally gone or your engine has blown up as I've personally found on many cars I've serviced with barely a litre in the sump pan.
I'd keep a regular weekly check on it as VAG cars do like to drink a litre every 900miles or so.
If you have vagcom I'm sure you can check to see if the sensor is working?. someone else will know better on this one.
ps I'm not saying it shouldn't work as it should in all honesty but I believe it's when the oil is bare minimum!.
M
« Last Edit: December 06, 2015, 04:01:46 pm by r5gtt »
Offline petesimcock
« Reply #2 on: December 06, 2015, 06:24:10 pm »
When that sensor fails there is a dashboard warning. Trust me, I've spent the last 5 months with it on on my car! Finally have it sorted, £80 for the new sensor! This is the one in the bottom of the sump
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #3 on: December 06, 2015, 06:27:24 pm »
Usually the yellow warning light illuminates on the dash when the sensor has failed.
Offline petesimcock
« Reply #4 on: December 06, 2015, 08:39:42 pm »
I didnt get a proper warning light, just a message on the MFD every time I started
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #5 on: December 06, 2015, 08:45:24 pm »
So the mfd message tells you of the low engine oil?.
M
Offline pd9264
« Reply #6 on: December 07, 2015, 12:04:20 am »
Cool. Just seems mental that it didn't show on mfd and oil was barely on dipstick. Better start checking the oil more regualy.
Offline petesimcock
« Reply #7 on: December 07, 2015, 06:49:35 am »
No, I think the MFD said 'oil level sensor workshop' or similar
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #8 on: December 07, 2015, 08:39:55 am »
Oh I see, that was because the switch had failed.
