Author Topic: noisey tappet  (Read 7847 times)
Offline doylebros
  • -Receive: 310
Re: noisey tappet
« Reply #15 on: December 19, 2015, 09:26:48 pm »
No one has ever mentioned setting the tdc mark up in any of the posts I've read  :surprised:
Some people are over cautious but it depends on the installers ability!
Offline r5gtt
  • -Given: 342
  • -Receive: 334
Re: noisey tappet
« Reply #16 on: December 19, 2015, 09:36:43 pm »
I'm wondering how hard can this be being a technician  :confused: simply remove the pump take out the follower and refit with the new part and hey presto  :signLOL: can't go wrong  :rolleye:
Unbolt and refit job done??? even a novice can do it so why scare people off???.
M
« Last Edit: December 19, 2015, 09:38:26 pm by r5gtt »
Offline doylebros
  • -Receive: 310
Re: noisey tappet
« Reply #17 on: December 19, 2015, 09:40:46 pm »
It's important to remember a lot of the peps are not mechanically minded and are asking for the best advice to give them a step by step guide as their employment could be in any discipline and are doing this for pleasure not paid employment - they just want help!
Offline r5gtt
  • -Given: 342
  • -Receive: 334
Re: noisey tappet
« Reply #18 on: December 19, 2015, 09:45:55 pm »
doylebros, I totally understand people on here are from all walks but telling them to set the tdc is something that a professional would do when replacing a t belt kit  :wink: anything extra is frightening even for me  :scared:  :P
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
Re: noisey tappet
« Reply #19 on: December 19, 2015, 10:22:20 pm »
Whats TDC can remember doing that when i did my belt.  :scared:
These guides are without the banjo bolt. Which can be a pita if you don't have the correct triple square bit. If you have an axx take a look at this.
http://myfastgti.com/volkswagen/threads/12734-DIY-HPFP-Removal-and-Cam-Follower-Replacement
I struggled doing mine the first time around then i found a screwdriver bit set that had an m8 that fitted a 1/4 inch ratchet which made it simple.
05 | Tornado Red | DSG
Offline r5gtt
  • -Given: 342
  • -Receive: 334
Re: noisey tappet
« Reply #20 on: December 19, 2015, 10:36:50 pm »
Thanks dazza, luckily I have all the tools necessary for thr replacement and I have a BWA engine it that makes my life any easier?. I have a very light rattle so will check this out for sure.
I had a nightmare with my OEM ugly box replacement as something fell down the turbo inlet and I had no idea what it was  :scared: :surprised: all I know is I was removing the silicon hose and something fell in!!! spent 30mintues with a torch and a hose clamp bent in the shape of a claw bit couldn't pick up what it was a looked black like rubber!!! luckily I had a pack of gum in my pocket so chewed three pieces and stuck it to the claw I made. OMGOSH :scared: I found a 25cm squared piece of bonnet trim stuck to the home made claw like wt*  :stupid: don't know how it dropped off... thay would have screwed my turbo for sure...
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
Re: noisey tappet
« Reply #21 on: December 19, 2015, 10:50:32 pm »
I always worry about things like that especially when my kids are in and out of the garage. I put a spray paint lid over the turbo pipe.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
Re: noisey tappet
« Reply #22 on: December 19, 2015, 10:54:33 pm »
I don't have the luxury of a garage. I just couldn't believe my worst nightmare came true and something fell in.  :surprised: Glad I got it out else tuebo off job and I'd rather not be doing that. First mk5 and already pi**** off with the way it's designed lol
Offline Scottymon
  • -Given: 83
  • -Receive: 125
  • UnNaturally Aspirated
Re: noisey tappet
« Reply #23 on: December 22, 2015, 01:03:17 pm »
I do the same, always putting a new plastic glove over the Turbo pipe or anything that needs to stay clean, went a bit mad when doing the ABS pump, as I was sh!t scared of fouling the connector with brake fluid.
Worth noting to those who haven't done the Cam Follower before, don't open the drivers door :pomppomp: it tries to prime the fuel pump!! :signLOL:
Offline r5gtt
  • -Given: 342
  • -Receive: 334
Re: noisey tappet
« Reply #24 on: December 22, 2015, 01:25:14 pm »
Just looking at that got me confused  :confused: :laugh:
Honestly mate, I would have covered it if I thought I was in danger of losing something down there but wt* that bonnet felt came from out if no where as it's a simple take off pipe and refit pipe job. For anyone reading this, MAKE SURE YOU HAVE CHEWING GUM TO HAND  :signLOL: as that saved my turbo for sure.
Note to you and everyone else is to remove the fuse for the fuel pump so it can't prime itself  :happy2:
Offline Scottymon
  • -Given: 83
  • -Receive: 125
Re: noisey tappet
« Reply #25 on: December 22, 2015, 08:24:33 pm »
Ha, yeah, good call which fuse is it btw?  Think my Cam Follower is in need of inspection soon.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
Re: noisey tappet
« Reply #26 on: December 22, 2015, 08:47:48 pm »
I think it's fuse number 2 but double check with your user handbook  :happy2:
