Author Topic: 2.0 FSI HPFP Cam Follower  (Read 2686 times)
Offline An0NyMOUs
  • A Nuisance
« on: December 18, 2015, 07:08:51 pm »
Does this engine have the HPFP  like the TFSI or is it a specific of that engine?
Sent from my Nexus 6 using Tapatalk
2.0 FSI 4motion
Offline slix
  • -Receive: 38
  • Stage 1 ED30 Owner
Re: 2.0 FSI HPFP Cam Follower
« Reply #1 on: December 18, 2015, 11:46:18 pm »
Yes.
The cam follower on your engine should be checked every 10k or so. I had mine replaced and had a little bit of wear but it's piece of mind to get it done. Only fakes 30 min or so to check or change.
Stage "1.5" ED30 [330BHP] Rtech
Offline Pesky jones
« Reply #2 on: December 19, 2015, 04:00:19 pm »
Unless you have the axx engine in which case it could take a little bwcause of the banjo bolt :fighting:
Offline An0NyMOUs
  • A Nuisance
« Reply #3 on: December 19, 2015, 04:07:38 pm »
I'm pretty confident it's not an AXX engine as its not a turbo. Thanks for the replies, I'll get off my a**e and actually have a look!
2.0 FSI 4motion
Offline shoaybmakda
  • -Receive: 54
« Reply #4 on: December 19, 2015, 11:45:45 pm »
It is possible to change the cam follower on a AXX engine without taking off the banjo bolt. My banjo bolt was completely cross threaded so loosened the fuel rail bolts and all the other bolts around the HPFP and slowly pulled it out and lifted it up. Do need to be careful but if the banjo bolt does cause alot of problems that is another option  :smiley:
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=q43tjukkveplchc670ubt5m9op&/topic,19740.0.html
« Reply #5 on: December 20, 2015, 12:17:30 pm »
AXX is turbo. 2.0TFSI
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #6 on: December 20, 2015, 01:36:24 pm »
rich83, I think the op meant he's car isn't an axx or turbo, not the axx engine itself.  :happy2:
