Author Topic: Will these fit?  (Read 2157 times)
Offline Chedburn
Will these fit?
« on: December 22, 2015, 10:19:24 pm »
Hi, sorry if this has been asked a lot before.
Looking at some wheels, will these fit without any problems?
Lowered 30mm
5x112
8j front 9j rear
225/40/18 on all.
Thanks!
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
Re: Will these fit?
« Reply #1 on: December 22, 2015, 10:37:10 pm »
Your going to need to put up the ET/offset....
Offline Chedburn
Re: Will these fit?
« Reply #2 on: December 23, 2015, 12:07:25 pm »
Sorry forgot to say, they are ET45
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
Re: Will these fit?
« Reply #3 on: December 23, 2015, 12:15:41 pm »
You might just get away with it, you'd need to do the arch screw mod on the front and add a little camber on the rear i'd suggest.
You might scrub a little on hard cornering at speed or with passengers in the back......
Offline Chedburn
Re: Will these fit?
« Reply #4 on: December 23, 2015, 12:25:35 pm »
Cheers for that, I'll do a bit of research into the camber and give them a go!
Offline jaffa
  • -Receive: 44
Re: Will these fit?
« Reply #5 on: December 23, 2015, 12:39:08 pm »
They fit nicely I had the same specs with a 215/40 front and 225/40 rear
Natural camber while lowering is fine for the back as mine never rubbed and front just need the screw mod
Offline Chedburn
Re: Will these fit?
« Reply #6 on: December 23, 2015, 01:00:46 pm »
Perfect, cheers for that!
Offline jaffa
  • -Receive: 44
Re: Will these fit?
« Reply #7 on: December 23, 2015, 02:44:01 pm »
heres a pic before i added camber
and after
Offline Chedburn
Re: Will these fit?
« Reply #8 on: December 23, 2015, 04:59:46 pm »
Nice one, looking good!
Offline JoeDarKa
  • -Given: 57
  • -Receive: 74
Re: Will these fit?
« Reply #9 on: December 23, 2015, 06:54:39 pm »
Mine scrubbed on 225s with the 9j rear
Offline Chedburn
Re: Will these fit?
« Reply #10 on: December 23, 2015, 10:05:07 pm »
Ahh did they scrub badly? Did you manage to sort it with a bit of camber?
