Author Topic: Xenon style headlights.. What to look for?  (Read 1746 times)
Offline jimmy-s3
« on: January 10, 2016, 05:57:56 am »
I'm thinking of getting some xenon style headlights for my Pirelli GTI. What should I look for and where's best to buy from?
Can I just use my Osram night breaker bulbs in them too?
Offline CarlW
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,92229.msg927100.html#msg927100
Re: Xenon style headlights.. What to look for?
« Reply #1 on: January 10, 2016, 07:26:16 pm »
There is a genuine set of xenon's up for sale at £300 including everything thats needed i believe that are currently on a Pirelli at VeeDubs up at Gateshead.. Check them out on Instagram if you have it or google them and give them a ring.
Offline AJP
  • -Given: 392
  • -Receive: 316
« Reply #2 on: January 10, 2016, 07:32:52 pm »
As for aftermarket, I think Depo make good ones. Not sure about bulbs, but I wouldn't mind knowing myself if I go for some Depos in the future.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #3 on: January 10, 2016, 07:52:33 pm »
You'll require a hid kit for the aftermarket depo or anything else.
Better to buy oem as they are quality and if you can get them for £300 that's a steal  :happy2:
Offline AJP
  • -Given: 392
  • -Receive: 316
« Reply #4 on: January 10, 2016, 08:22:45 pm »
I'm not 100% sure but I think you can use normal H7 halogens, in the Depos at least.
Getting oem xenons in and working properly can be quite involved.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #5 on: January 10, 2016, 08:37:31 pm »
Yes you can use the H7 bulbs but they won't look as good as a hid kit but that's entirely you're choice.
Hid fitment is more involved than you're oem xenon headlights but depends in you're skills in fitting them and they are plug play too.
If everything is there then all you need to do is activate them in vcds with shutters fitted and a way you go?.
Offline AJP
  • -Given: 392
  • -Receive: 316
« Reply #6 on: January 10, 2016, 08:54:29 pm »
I'm yet to venture into the world of vcds.. haha!
Yeah that's pretty much what I've learned from skimming a few posts. Only thing that'd really put me off Depos is if the beam pattern using normal bulbs ended up worse than in oem non-projector headlights.
More research needed for me. It's a long way down the list anyway... more power first.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #7 on: January 10, 2016, 09:09:01 pm »
 :signLOL: you'll learn ad we all have to start somewhere  :P
I'm sure if you're not capable of programming them in, a forum member close to you can do it for you for a small fee.
No one works for free these days.  :signLOL:
I went out to someone 5 miles away as he couldn't fire his tt up and after an hour of tinkering I found he had put the wrong plugs in causing over fuelling and a non start  :signLOL: some people ey.
Have a look here depo xenon with H7R hid
http://www.mk5golfgti.co.uk/forum/index.php/topic,102841.15.html
« Last Edit: January 10, 2016, 09:16:42 pm by r5gtt »
