Author Topic: AWD / Quattrro Conversion  (Read 48883 times)
Offline olethalb
  • -Receive: 31
  • My Ride: A4 DTM - TOURAN
« on: January 20, 2016, 09:17:09 am »
As prices are coming down and seems to be more popular i thought i'd share my experience with performing FWD to Haldex conversion - if anyonew has any part numbers or something i've forgotton feel free to chime in  :happy2:
First, Parts;
Gearbox with transfer box
transfer box to block mount / bracket with bolts
heat / driveshaft shield that atattches to the above
Drivers (right) driveshaft (passenger shaft is same as fwd)
front quattro ARB
prop shaft complete
prop shaft mounts 1k0 804 332 and 1k0 804 331
prop centre joint heatshield + bolts
complete rear assy - subframe/ diff/ arms / hubs / shaft / haldex / arb + mounting bolts
fuel tank from quattro (saddle) inc tank straps / heatshield / sender unit / quattro pump (ttrs popular option)
abs and esp controller from quattro car
some sheet metal as cutting of the wheel well is required
rivnuts or similar as tank straps land in a different place
exhaust from quattro car or modify existing to snake around diff
there are also wiring mods / additions that need to be done to get it all up and running (don't forget a decent earth strap from haldex to chassis)
Some of the parts together
Box without transfer box fitted
Tank with second sender fitted
Quattro vs fwd rear arb
Rear assembly
Ttrs pump
Rear frame comparison
Tanks
Wheel well trimming
Closing up wheel well
Tank with heatshield / prop and rear assy fitted
Exhaust route modified
Fwd vs quattro right side shaft
Transfer box and bracket fitted
Prop mounts welded in place
Prop fitted with heatshield and exhaust
Esp and abs units used note esp mounts upside down (bracket made)
Now some pics of wiring if i can remember what was what....
Green and white jumper / loop wire added to abs plug
Can wires tapped into airbag plug loom
Ignition live to haldex tapped into cecm plug
Additional sender wire (yellow in pic) added into plug for clocks
I have more loom pics but cannot find them at the mo :(
« Last Edit: February 28, 2019, 11:29:36 pm by dazza »
Touran TFSI Quattro | stage 2+ BHZ | UK's first
Offline xjay1337
  • -Receive: 377
Re: AWD / Quattrro Conversion
« Reply #1 on: January 20, 2016, 09:59:06 am »
Very useful thanks for doing this olly.  :happy2: :happy2:
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #2 on: January 20, 2016, 10:38:30 am »
That's excellent mate, I'd love to have the balls to do that  :jumping: :happy2: :happy2:
Was it all just bolt on parts?.
Is it all working properly?.
Also how much for the complete conversion please?.
« Last Edit: January 20, 2016, 11:10:22 am by r5gtt »
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=d6bt2h4gt0vag7n7nut617g0in&/topic,90967.msg917089.html#msg917089
« Reply #3 on: January 20, 2016, 11:12:20 am »
Nice one olly. Have you started on your next project yet?
r5gtt have a read of this my favourite build on the forum.
http://www.mk5golfgti.co.uk/forum/index.php/topic,96044.0.html
05 | Tornado Red | DSG
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #4 on: January 20, 2016, 11:55:29 am »
Thanks dazza  :happy2:
What a great read and an awesome conversion  :jumping:
« Last Edit: January 20, 2016, 01:54:24 pm by r5gtt »
Offline swebster94
« Reply #5 on: January 21, 2016, 09:42:55 pm »
Ace!  :happy2:
Was only thinking the other day I should have bought a 4motion!
If only the parts were cheaper....
2005 Reflex Silver GT TDI
2010 Black Tiguan R-Line
Offline bluo
« Reply #6 on: January 26, 2016, 02:16:47 pm »
What generation haldex you using?
Offline omeydz
  • -Receive: 50
« Reply #7 on: January 26, 2016, 08:45:17 pm »
Interesting to know what went into the mod! Cheers for this :)
Recently back on the forum! Good to be back
Current Rides
Mazda RX8 231bhp ( very different little rocket lol!)
SOLD
2007 MK5 Golf 1.4 FSI
2007 Golf MK5 GTI DSG
2008 Audi A5 3.0TDI
Edi30boi
« Reply #8 on: June 03, 2018, 12:25:21 am »
Hi there. Any chance of a wiring guide for this 4wd. Done everything. No communication from awd.  Vcds has registered the awd is in so. Any help pleeeaaassseeee???
Offline kam760
  • On the search for an edition 30.
  • My Ride: On the search for one...
« Reply #9 on: June 15, 2018, 11:18:40 pm »
Impressive
Vag-shane
« Reply #10 on: July 10, 2018, 09:13:43 am »
Does any one know the guyntjatbdid the bulid I'm doing one my self.and I'm.stuck
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
« Reply #11 on: August 16, 2018, 10:04:50 am »
You make it look easy big man...  :happy2:  Great write up!  :evilgrin:
Silver is the way !
Offline ProffB
« Reply #12 on: February 22, 2019, 11:38:41 pm »
Hi guys,
Can someone please tell me how to wire up the 3 wires from the additional (2nd) fuel sender (suction-jet pump) to the car. I have recently installed a AWD drive tank on my FWD Golf MK6 and need to wire up the 2nd pump to the car but have no idea where each wire is supposed to connect to. Please help me :confused:
Offline FranticG
« Reply #13 on: October 06, 2019, 08:38:28 pm »
Just a long shot. Anyone got any wiring diagram please for this?
Offline jason_rmh
  • -Given: 69
  • -Receive: 81
« Reply #14 on: October 15, 2019, 12:16:47 pm »
There's a guy on Facebook, Shane Rahman, selling a complete conversion kit who also offers to help with wiring, having done a few already.
May be a member on here?
VCDS (Preston, Lancashire)
