Author Topic: Strange hesitation under load  (Read 5425 times)
Offline K1NGY14
« on: February 09, 2016, 07:41:53 pm »
Hi everyone,
I have a bit of a strange problem with my 08 GTI. Basically when the car is accelerating under load (heated seats on and heater on high) I get a slight hesitation around 1500/2000 rpm, but after that it's smooth right through the rev range.
I have recently had my DV changed so that can't be an issue, I have also had the car scanned with VCDS and it is completely clear!
Does anyone have any ideas about what might be the problem?
Offline K1NGY14
Re: Strange hesitation under load
« Reply #1 on: February 10, 2016, 07:29:37 pm »
Anyone?
Offline AJP
  • -Given: 392
  • -Receive: 316
« Reply #2 on: February 10, 2016, 07:41:10 pm »
Could be a coil pack. Not sure if you'll definitely get a fault code if it's intermittent.
Offline K1NGY14
« Reply #3 on: February 10, 2016, 08:59:25 pm »
Would that also be the reason that sometimes my car struggles to start?
It doesn't completely fail but it sounds like it's struggling.
Offline AJP
  • -Given: 392
  • -Receive: 316
« Reply #4 on: February 10, 2016, 09:06:51 pm »
Maybe part of the same problem, maybe something completely different!
Probably best to start at the coils as they're at the cheaper end of possible suspects. It's not really a specialist job to diagnose or fix, so you could do worse than quickly nipping the car into a local garage, they should be able to rule things out at the very least pretty quickly.
As far as I know they'd be able to check the coil packs without relying on fault codes.
Offline K1NGY14
« Reply #5 on: February 21, 2016, 09:21:26 pm »
So I thought I'd had the problem sorted.
I got down to Awesome GTI (cracking service) and had all of the coil packs changed. Whilst it was being looked at I was advised that one of my spark plugs had oil on it and they needed to be replaced.
Great news I thought, that's the problem sorted. So after coil packs, spark plugs and the oil problem sorting I still have the hesitation under load
Any ideas anyone?
Offline AJP
  • -Given: 392
  • -Receive: 316
« Reply #6 on: February 21, 2016, 09:36:26 pm »
Still no fault codes I take it?
Bit oldskool, but have you tried pulling the MAF?
Offline Ricky123
  • -Receive: 27
« Reply #7 on: February 21, 2016, 10:25:14 pm »
If you don't have any fault codes showing then maybe have a check over all the vac pipes and PCV pipes for any splits/cracks.
59 red mk6 GTi 5dr
57 mk5 1.9 TDi match
Offline K1NGY14
« Reply #8 on: February 23, 2016, 02:01:07 pm »
No nothing at all, I have got it going back into the garage on Thursday as they think it might be a possible fuel injector fault! I just hope it is because it's really starting to annoy me now!
Offline K1NGY14
« Reply #9 on: February 26, 2016, 03:49:00 pm »
So I've finally had the problem fixed! It turned out to be a dodgy MAF so £130 later it's sorted!
Offline AJP
  • -Given: 392
  • -Receive: 316
« Reply #10 on: February 26, 2016, 03:59:53 pm »
Do I win a prize?!
Just kidding, glad you got it sorted pal
Offline K1NGY14
« Reply #11 on: February 27, 2016, 01:04:20 am »
Do I win a prize?!
Thanks for the advice mate!
Also my car finally threw up a code which was the MAF, now I've had that changed to I need to get the code cleared or will it clear itself?
Offline AJP
  • -Given: 392
  • -Receive: 316
« Reply #12 on: February 27, 2016, 12:38:27 pm »
Probs best to clear all codes, go for a varied drive, then scan for new codes.
Offline K1NGY14
« Reply #13 on: March 06, 2016, 11:38:15 am »
Back with the thread revival!
The mystery hesitation is now back, it's back but not as bad as before.
So now I've had my MAF, Coilpacks and spark plugs changed and it's still not sorted it!
What else is left?
Offline doylebros
« Reply #14 on: March 06, 2016, 11:57:02 am »
The fuel filter is not listed as a service item has it been changed?
