Are we referring to the bracket on the engine side and if so yes it is.
Yay
Removing the cambelt and head should be easy compared to what you've already done, re-fitting is the harder part
Ha oh really? What are the difficult bits of refitting?
I think I remember someone saying about the engine mount being a pain to remove @r5gtt or @dazza maybe?
Cambelt timing can scare people off but on VW engines that's easier because you've only got to line up one cam pulley. You've then got to make sure that everything is 100% clean between the head to block mounting faces and correctly torque the head down.
If you've got the time, tools and patience there's no reason why you can't do it, it just about confidence.
I had a cambelt snap 200 miles into a running in period on my old Integrale 16 valve after paying someone else to rebuild the engine. That suffered bent valves and I repaired it myself in the end and I'm no mechanic, all I did was towed it to a garage to fit a new cambelt because back then I was scared of cambelts having had 1 jump and destroy the engine and then another one snap
Ok. Ill keep telling myself I can do it then!
I’m sure im getting ahead of myself again but…
Say I remove head this weekend. Valves have bent and I decide to get a new cylinder head. I refit everything and all ready to go. I turn on engine and theres still an oil pressure warning light. I will have wasted a lot of time and money and probably would have been better off going for a new engine to begin with.
I’m praying that it is just a new cylinder head as I think I might be able to remove and refit myself, and it will just be the cost of the new head, bolts, gaskets, coolant etc.
Really I think Id need to eliminate the oil pump, but that will mean dropping the sump again, and trying to get the balance shaft unit off (something I can’t find much info for). As I’ve mentioned plenty of times
if the tensioner had proved the reason for the oil pressure message I would be confident in just replacing the cylinder head. But then again I don’t know the order of events in which the chain snapped so cant definitively rule the tensioner being the root of the problem out.
Bit of a mental battle im having here
