Author Topic: URGENT oil pressure stop engine  (Read 218759 times)
« Reply #615 on: April 06, 2016, 06:07:38 pm »
You know you can manually check the cam position? There are notches you can line up.
Offline doylebros
« Reply #616 on: April 06, 2016, 06:09:20 pm »
A missing bolt can cause vacuum leaks which gives rough running like your experiencing so if you've got something to use temporary put it in there.
Reclean away any oil spillage from past running.
Take nothing apart as you know what the leak is and the above bolt will cure it  - Build it back up as it was before the strip down.
Simple steps so you know each stage is done right.
A fully charged battery to prevent unnecessary electrical DTCs codes.
Do an autoscan and clear all DTCs so you know where your starting from. Then rerun it and do your VCDS testes for timing and report back.
Offline Pesky jones
« Reply #617 on: April 06, 2016, 06:25:11 pm »
There was no bolt before the strip down. Dont know how long its been missing. Dont think I have any bolts that will fit, will have to get it from tps.
although when I removed the other two bolts to take the vacuum pump off the cover (to look for plastic bits) I might have put the two bolts back in different holes by mistake. Therfore potentially leaving the third hole that had a bolt in it previously without a bolt which makes sense because I never noticed a pool of oil before.
Offline Pesky jones
« Reply #618 on: April 06, 2016, 07:45:57 pm »
So  :sad1: the timings well out 28 requested and -3.5/4 on actual! How could it be this far out? Is it worth me trying the timing again? I dont know how much better id get it the second time around.
Its strange, it almost sounds perfect on start up for about twnety seconds, then gets progressively worse. After twi minutes its really bad.
« Last Edit: April 06, 2016, 07:47:40 pm by Peskyjones »
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
« Reply #619 on: April 06, 2016, 07:54:34 pm »
After 20 seconds or so the cam advance changes, and the cold start routine designed to superheat the catalytic converter stops..... Sounds like the N205 is working? Either way timing is most definitely out and will need doing again.
Offline Pesky jones
« Reply #620 on: April 06, 2016, 08:00:30 pm »
Strange, I mean I cant see why it wouldnt be working, as I snapped the plastic but glued it back on, the two metal prongs still protrude through and I think touch th sensor. But p1351 fault code says n205 valve broken.
I dont mind trying to do the timing again but I dont see how I went so wrong the first time. A difference of 30 odd degrees seems like a lot. I thought I got it spot on! Its a shame there arent marks like the crankshaft and exhaust cam pulley.
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
« Reply #621 on: April 06, 2016, 08:06:30 pm »
Its an open circuit fault, needs replacing if you are getting this. Once replaced, check block 091 again and see if the reading has improved
30 odd degrees is only a tooth or two out
Offline Pesky jones
« Reply #622 on: April 06, 2016, 08:17:38 pm »
Ok well il replace the n205 tomorrow and log it again. So is there a chance the timing might not be out?
Offline doylebros
« Reply #623 on: April 06, 2016, 08:20:55 pm »
The vehicle starting and running is the most important factor and you've got that.
If I was you I would leave the strip down for rechecking the timing till after you've tried the valve, as said above. If it shows no improvement it's back to checking the timing but you'll be much quicker and more confident and may even enjoy it.
My thoughts are its only one tooth out but tomorrow will tell us.
Offline Pesky jones
« Reply #624 on: April 06, 2016, 09:04:11 pm »
Ok cheers guys. Fingers crossed its just the valve then.
Here's the video from start up today
You can see near the end of the video when I rev it the noise goes and also the engine completely stops shaking!
« Last Edit: April 06, 2016, 09:07:58 pm by Peskyjones »
Offline Pesky jones
« Reply #625 on: April 07, 2016, 08:59:16 am »
@Dan_FR Just wondering what you change your mind here?
I'm really hoping the valve stops the noise and corrects the timing issue!
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
« Reply #626 on: April 07, 2016, 09:15:22 am »
Something can still work, even if not fully or correctly yet still flag a fault, if the resistance is too high or too low. It could be other changes rather than just the N205 that affect the idle, as during the same cold start procedure, there is also a period of dual fuel injection where the injector fires twice.... again aimed at warming up the cat which could be affecting this.
VCDS will tell you for sure whether the cam adjuster is doing anything. To be honest I didn't see what fault codes you'd picked up previously - too many pages to go through! Let us know what happens when you get an N205 on there. Might be worth going to a few scrapyards to find one as I'm pretty sure its the same part on most if not all 2.0 TFSI lump
Typically I always see this thread when I'm in work and can never view any media  :signLOL:
  • -Receive: 690
« Reply #627 on: April 07, 2016, 09:31:11 am »
Yep, the cam adjuster is not advancing.   It's not possible to get the physical timing that far out.  The cam locking tool simply won't allow that much misalignment.  30 degrees is a lot more than one tooth off.
Offline Pesky jones
« Reply #628 on: April 07, 2016, 09:52:19 am »
I'm picking one up from TPS today at lunch, didn't think about scrapyards. At least Ill know I have an operational one! Will let you know
I'm not sure I completely understand, correct me if i'm wrong - its not possible for me to get the physical timing 30 degrees out - so it must be the current n205 not doing its job properly? But if 30 degrees is more than one tooth, then I must have got the physical timing wrong? Surely the adjustor cant do its job if its a tooth or more out of timing?
  • -Receive: 690
« Reply #629 on: April 07, 2016, 10:20:35 am »
Yep, the N205 isn't advancing the cam.
I very much doubt it's a physical timing issue.  What does measuring block 93 say?  You're looking for around -2KW.
