Author Topic: URGENT oil pressure stop engine  (Read 218337 times)
Offline Pesky jones
« Reply #660 on: April 09, 2016, 02:39:14 pm »
Crankshaft at tdc
In this pic it looks corectly timed
But then if I move the phone up or down
I think it looks most perpendicular in the second photo, which makes me think it is timed correctly
Offline vRSAlex
  • -Receive: 253
« Reply #661 on: April 09, 2016, 02:44:43 pm »
Unto the two bolts holding the top of the cam cover.  Then see where the rear of the tooth on the pulley lines up to.
Follow AKS tuning on Facebook
Offline Pesky jones
« Reply #662 on: April 09, 2016, 02:45:40 pm »
UPDATE.
whilst turning the inlet cam anticlockwise I could push the locking tool in place with a little bit of force and it is now in correctly.
Il now remove the adjustor and start refitting the chain?
Offline vRSAlex
  • -Receive: 253
« Reply #663 on: April 09, 2016, 02:46:29 pm »
UPDATE.
Sorted.
Offline Pesky jones
« Reply #664 on: April 09, 2016, 03:05:21 pm »
Now I guess its a case of luck whether I get it timed up properley becauee I wont know untill its all back together and I turn it on???
Offline doylebros
« Reply #665 on: April 09, 2016, 03:14:00 pm »
Use tipex or paint to mark the chain and sprockets before removal - so you know you've made an adjustment.
Offline Pesky jones
« Reply #666 on: April 09, 2016, 03:19:17 pm »
Have done :)
Offline doylebros
« Reply #667 on: April 09, 2016, 03:32:49 pm »
Also check the back of the adjuster that the guide pin is still there just in case.
Offline Pesky jones
« Reply #668 on: April 09, 2016, 03:33:18 pm »
So it the adjustor went on so much easier then last time, two seconds. The notches look more vertical and its one tooth different. You can see in the picture how it is now...
Note the tip ex on the sprocket and the chain
The guide pin is still there doylebros
Offline Pesky jones
« Reply #669 on: April 09, 2016, 03:39:30 pm »
Locking tool also goes in nice and easy now
Offline doylebros
« Reply #670 on: April 09, 2016, 03:40:54 pm »
That's the tensioner guide pin - check the back of the adjuster you removed the bolt from.
All positive though.
Offline Pesky jones
« Reply #671 on: April 09, 2016, 03:43:04 pm »
Sorry dont think I explained properly, I didnt post that photo to show the tensioner pin, I posted it to show the sprocket is now on a different link of the chain.
I checked the adjustor tab that slots into exhaust camshaft and it is fine
Offline Pesky jones
« Reply #672 on: April 09, 2016, 04:01:08 pm »
Well things were going well, so naturally something had to go wrong.
I thought id replace the o ring on the vacuum pump to see if that was the oil leak. When I I took it off the cam chain cover, it had no o ring at all! See before and after pictures for with and without o ring
Youll also see that when I was tightening the bolt for the vaccum pump back on to the cam chain cover its broke the bolt hole of the vaccum pump off.  New vacuum pump :(
I think im just going to put this one back on with two bolts (it only had two before anyway! Ones always been missing) and then replace the pump at a later date.
Thoughts?
Without o ring
With o ring
Offline doylebros
« Reply #673 on: April 09, 2016, 04:25:07 pm »
That photo without oring has an oring in unless my eyes are playing tricks.
Offline Pesky jones
« Reply #674 on: April 09, 2016, 04:29:06 pm »
Well its not the same material and its built into it so its flush with the metal. Thr oring ive put on now is a perfect fit for the circumference and also it is actual sealing it before it wiuld have been metal on metal, here it is now
Il guess well see if it stops leaking!
