Author Topic: Remove rear wiper metal inner.  (Read 1581 times)
Offline glasgowdubber
« on: March 18, 2016, 02:33:56 pm »
Basically the rear wiper has corroded and was hanging off, when I removed it, it's left the metal part in the centre, impossible to get off!
Anyone any tricks for removing this? It's supposed to be a common problem.
Offline TAPPY
  • -Receive: 56
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,103290.0.html
Re: Remove rear wiper metal inner.
« Reply #1 on: March 18, 2016, 06:29:54 pm »
If it's the bit I'm thinking of you can try wd40 and some grips and try wiggling it or you will need to cut it and it should then open up and will come off hope this helps I have prob not explained very well
« Reply #2 on: March 19, 2016, 01:23:46 am »
That's the very bit, tried the wd40 and still won't shift, looks like it's gonne need to be cut off which is what I wasn't wanting to do
« Reply #3 on: March 19, 2016, 08:19:44 am »
Have you tried using a puller?
