Author Topic: Canbus Version for Mk5 Headunit Swap  (Read 17958 times)
Offline RichL
Re: Canbus Version for Mk5 Headunit Swap
« Reply #15 on: May 01, 2016, 08:11:32 pm »
After installing my RCD510, measured the current draw and found that after a couple of minutes it settled to a reading of zero (on a meter that reads down to 1 milliamp).  Assuming on this basis moment that my version K gateway module is not going to cause me a problem...unless anything kicks back in and starts drawing current after the car has been off for a while?
Offline doylebros
  • -Receive: 310
« Reply #16 on: May 01, 2016, 08:28:22 pm »
That's quick to settle normally a higher value - how and where have you introduced your meter I to the circuit?
Offline doylebros
  • -Receive: 310
« Reply #17 on: May 01, 2016, 08:30:21 pm »
Offline RichL
« Reply #18 on: May 01, 2016, 09:52:27 pm »
Disconnected negative battery lead, put meter between the lead's clamp and the -ve battery terminal, meter set to read current across its high-current capacity terminals.  Meter was definitely working - we had readings that reduced in three steps before eventually settling to zero.
Offline doylebros
  • -Receive: 310
« Reply #19 on: May 01, 2016, 09:57:01 pm »
Well your values don't match the TSB guidelines but if your meter is working and calibrated then your results say you've got nothing to worry about but that not close to the last reading I had when looking for a fault. :driver:
Offline RichL
« Reply #20 on: May 01, 2016, 10:01:16 pm »
Have to say (albeit with my limited knowledge), I was surprised to see it absolutely at zero, was fully expecting to see some nominal low draw.  Not counting my chickens just yet!
Offline RichL
« Reply #21 on: May 01, 2016, 10:05:31 pm »
From recollection (should have written it down when testing on Saturday for accurate account); upon connection got about an amp of draw for a few secs, then fell to 130mA, then to 80mA then after a minute (maybe two from connecting) reading fell to naff all.
Offline doylebros
  • -Receive: 310
« Reply #22 on: May 01, 2016, 10:13:20 pm »
I find a twenty minute test gagging the doors and set the alarm so it goes to sleep correctly and 30ish MA  reading if I remember correctly.
So if you have hassle do another test and see what real values you do have. :happy2:
Offline irish_ram
  • -Given: 200
« Reply #23 on: May 02, 2016, 12:21:50 pm »
1K0 907 530 K  same as mine NO battery drain :happy2:
Mine is this model but do you know what software version yours is as mine is 0020 and I have heard out if the three K versions that 2 drain and one does not
Offline Shoduchi
  • -Given: 220
  • -Receive: 430
« Reply #24 on: May 02, 2016, 12:27:49 pm »
You can check this list of CAN Gateways that are compatible with the 3rd generation radios: http://wiki.ross-tech.com/wiki/index.php/Navigation_System_(RNS510)_Retrofitting.
You'll need VCDS to know which software version your K CAN has.
Offline irish_ram
  • -Given: 200
« Reply #25 on: May 02, 2016, 02:03:41 pm »
Yeah I saw that and mine is not on the list which seems to point to it being compatible although someone said there were only 3 versions of the K which mine is slightly different
1K0-907-530-K    0021    No    Replacement only
1K0-907-530-K    0170    No    Update available
1K0-907-530-K    0178    Yes    -
Offline Pashka
« Reply #26 on: May 04, 2016, 08:20:45 pm »
0020 not compatible pal, simple thing - numbers shows sw number, higher number higher soft, compatible is only 0178, 0020 is the lowest sw available. if would be option with 02xx it would be compatible.
06 1.9 TDI Owner. Retrofits: Bixenons, Drls, Full GT/GTI exterior, RNS510+MDI+Premium Bluetooth+RVC+OPS, Full Fis, MFSW, Cruise control, TPMS, Polar Fis, Boot pop up and more.. :)
Coding, diagnostic and retrofits in Leeds
Pre coded Can Gateways for battery drain issues with RNS510 and similar headunits
Premium Bluetooth modules/kit
RNS510 Service - codes, maps/firmware updates
Latest V8 West EU maps update service for RNS315
Offline Gooky
« Reply #27 on: May 06, 2016, 10:44:04 am »
Just reading through all your feed back but can any1 tall me where the CanBus Gateway can be located in my ed30 as i'm looking in to upgrade my if needed, but I cant seem to see it or am I just being blind  :doh:
Offline Shoduchi
  • -Given: 220
  • -Receive: 430
« Reply #28 on: May 06, 2016, 12:48:00 pm »
The location changes depending on the year it was built. Search online, I'm sure you'll find a guide. :wink:
Offline GTiBlues
  • Mr Blues
    • Bookface
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,75444.0.html
« Reply #29 on: May 16, 2016, 06:33:04 pm »
1T0035680P is my RNS510. Im in the same position as you in needing to update my Canbus. TPS has came back with a part number of '7N0907530AKZ00', does it ring a bell with you? Would anyone know if it'll be fine with my RNS?
