December 22, 2025, 04:32:06 am
All Things Mk5
Mk5 General Area
Euro carparts 25% off this bank hol, need disc brake info so I can order please!
Topic: Euro carparts 25% off this bank hol, need disc brake info so I can order please! (Read 1240 times)
Lewo
Won't Shut up.
-Given: 8
-Receive: 35
May 02, 2016, 09:29:49 pm »
Alex said that Brembo are the ones to get so are the prices good for the discs & pads with the 25% off these prices?
Also What size are the discs F & R on a 56 plate GTI?
http://www.eurocarparts.com/brake-disc
http://www.eurocarparts.com/brake-pad
rich83
Just look at my post count
-Given: 165
-Receive: 802
My Ride:
Re: Euro carparts 25% off this bank hol, need disc brake info so I can order please!
Reply #1 on:
May 02, 2016, 09:55:48 pm »
ECP is usless....
Select my car (GTI)
Select brakes
It lists about 4 different sizes....
You want 312mm front. 286mm rear
https://www.justgiving.com/thenational3peaks
howie1987
Won't Shut up.
-Given: 92
-Receive: 20
Reply #2 on:
May 02, 2016, 10:06:34 pm »
Carpartsforless are the same company. prices are cheaper and if buying brake discs you should be able to use the £15 or £10 off code on they're homepage.
Worth comparing prices anyway.
Lewo
Won't Shut up.
-Given: 8
-Receive: 35
Reply #3 on:
May 02, 2016, 10:11:02 pm »
Cheers guys, I'll try CPFL any where else also worth comparing prices.
rich83
-Given: 165
-Receive: 802
My Ride:
Reply #4 on:
May 02, 2016, 10:14:50 pm »
Or... mtec... they are very reasonable
All Things Mk5
Mk5 General Area
