Author Topic: Low fuel rail pressure, limp mode  (Read 13881 times)
mcochra
« on: May 03, 2016, 04:55:14 pm »
All,
I have an 07 mk5 gti with around 78,000 miles. The car keeps coming up with the low fuel rail pressure fault code. I have had the fuel filter, cam follower and thrust sensor replaced. The fault code has been cleared, have driven around 50 miles running fine and then the car goes back into limp mode with the same error. The garage have reccomended hpfp and then even a new ecu if all else fails. Any suggestions???? Dont fancy splashing out £1500 for a new pump and ecu
Offline th3_f15t
  • -Receive: 183
Re: Low fuel rail pressure, limp mode
« Reply #1 on: May 03, 2016, 06:12:12 pm »
You can pick up an upgraded HPFP off here and a used ECU of eBay for less than that! There's normally a pump or two for sale every month so keep your eyes posted, may as well fit an upgraded one as it makes a difference even at stock.
Again, keep your eyes peels for someone breaking a GTI on here as they may be able to help you source some replacement parts cheap.
Offline Nasir
« Reply #2 on: May 03, 2016, 06:36:09 pm »
What is the exact fault code?
Read this and note what it says about the 2.0 TFSI engine: http://wiki.ross-tech.com/wiki/index.php/16471/P0087/000135
No need to guess what's wrong.
Shadow Blue 2007 GTI DSG (Standard)
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
« Reply #3 on: May 03, 2016, 07:38:14 pm »
Firstly, what are your fault codes?
Have you replaced the G247-high fuel pressure sensor on the rail? If you find the hpfp and lpfp are pumping as they should or think they are...you can try this before the spendy bits. The p/n is 06J-906-051-D
The G247 is on the rail between cylinder's #1 and #2  injectors(pic was borrowed from cousin N. R. Webb):
« Last Edit: May 03, 2016, 07:59:25 pm by ROH ECHT »
Offline doylebros
« Reply #4 on: May 03, 2016, 07:45:51 pm »
And if you need one which fail regularly look here http://www.mk5golfgti.co.uk/forum/index.php/topic,106431.0.html
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #5 on: May 03, 2016, 08:12:46 pm »
Good sales tactics  :signLOL:
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #6 on: May 03, 2016, 08:14:03 pm »
All,
Dont know what garages you use but I'd advise a change to someone who is vag competent  :happy2:
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #7 on: May 04, 2016, 02:57:58 pm »
That code relates to the camshaft lobe that controls the HPFP which in turn may have excessively worn causing fuel rail pressure fluctuation and going into limp mode around 4500rpm or WOT.
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
« Reply #8 on: May 04, 2016, 03:17:03 pm »
The fault code is P0087 - Fuel Rail/System Pressure: Too Low
The receipt I got from the garage says...new 'Thrust Sensor' part no S06J906051C.
Is this the G-247 high pressure fuel sensor you are talking about on the rail?
No, that's the "G410-Low Fuel Pressure Sensor" attached to the hpfp.  I would check, or better yet replace, the cam follower before you damage the hpfp and intake valve.  If fault is caused by the G410...it is incapable of reading the low pressure...and then the ecu cuts power because the ecu thinks the hpfp is unable to make high pressure. If the G410 sensor is not faulting, again, it may be a hardware issue like the cam follower or even a fuel filter...something upstream. But you have completed repairs? You mentioned new sensor on a receipt...
« Last Edit: May 04, 2016, 03:38:44 pm by ROH ECHT »
