Author Topic: Inline thermostats 06 BWA DSG, one or two?  (Read 7053 times)
Offline macarthur.2000
« on: May 08, 2016, 08:23:49 pm »
Hi,
2006 gti dsg BWA engine. I am in the process of renewing my cooling system and have purchased 2 inline thermostats to replace the 2 I should apparently have.
I've replaced the dsg one under the battery, but can not change the one by the radiator as its not there. Far as i can see from etka and a number of other sites, links etc it should be on the rubber hose attached to the lower end of the solid pipe bolted to the dipstick, am i wrong? I've removed the large hose/plastic pipe and there is nothing hiding behind it. Its not there.
Two things: should it be there? And because its just the rubber hose, should i add it, just cut the hose and insert so to speak. I'm obviously reluctant to do this because it seems wrong.
Thanks.
Neil
Offline r5gtt
  • -Given: 342
  • -Receive: 334
Re: Inline thermostats 06 BWA DSG, one or two?
« Reply #1 on: May 09, 2016, 12:36:57 am »
« Reply #2 on: May 09, 2016, 09:29:04 am »
Thank you,
I actually used this excellent guide when I started changing them, and the second thermostat is just not there. If I had thought when I was under the car I would have taken a picture.
Its a pickle.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #3 on: May 09, 2016, 10:27:02 pm »
Maybe it's been taken out?. There's no harm in fitting one in place as I'm sure there was a reason to have three in the first place.
« Reply #4 on: May 09, 2016, 11:25:22 pm »
That was my thinking, gona have a go changing tha main thermo tomorrow, so will do it then. Will take pics if i remember.
Thanks for the replies.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #5 on: May 09, 2016, 11:27:54 pm »
No worries and make sure the inline will fit in between the pipe before splicing into it  :happy2:
Patrick2691
« Reply #6 on: May 10, 2016, 08:23:48 am »
06 BWA doesn't have a second one I believe that was pre 06. They just have the one above the oil cooler like mine did. I also ordered two so now I just have a spare.
Sent from my LG-H955 using Tapatalk
Offline Pesky jones
« Reply #7 on: May 10, 2016, 09:02:58 am »
15£ posted?
« Reply #8 on: May 10, 2016, 09:19:11 am »
Ahh, that makes more sense then. That means I have a spare also. it was confusing the nonsense out of me, especially when the VW dealer I got the part from agreed that it should have 2.
Offline Pesky jones
« Reply #9 on: May 10, 2016, 09:53:50 am »
well I need one so if anyone wants to sell....
« Reply #10 on: May 10, 2016, 10:19:50 am »
dont really use forums that much, so I'm assuming if you PM me we can arrange for you to buy it?? my apologies if that's not how its done.
Offline Pesky jones
« Reply #11 on: May 10, 2016, 11:04:55 am »
You cant read PMs yet because you havnt posted enough. Here is the pm I was going to send you...
The norm is to use paypal. Unless you a 100% trust the person, you should never pay for an item with the gift option. It should always be for goods and services. The goods and services option takes a small fee from the sellers account (usually for 3% ish).
for example, if I were to send you 15£, you would only receive £14.55. So instead, I send 15.46  and you receive the full £15. This protects myself from fraudulent activity. Obviously in our case you wont need to worry about this, as It is me that is sending the money.
Apologies if you already know all this, but incase you didn't - its good to know. Its always worth paying a little bit extra for protection against fraudulent activity.
Are you happy with £15 for the thermostat?
If you are, send me your paypal email adresss (if you don't have one, it doesn't take long to set one up) make sure the email address is correct
I send you my delivery address, and then I send the money to your account and you send me the thermostat :)
Tom
Offline GTIEagles
« Reply #12 on: May 10, 2016, 11:45:37 am »
Yeah can confirm the AXX only has 2 of them. I wonder if that means it heats up quicker?
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #13 on: May 10, 2016, 12:03:07 pm »
My AXX only has one.
05 | Tornado Red | DSG
Offline Pesky jones
« Reply #14 on: May 10, 2016, 12:09:41 pm »
AXX manual 1 inline 1 main
AXX 04-05 DSG 2 inline 1 main
AXX 06 DSG 1 inline 1 main
BWA + all other engine revisions manual/DSG 1 inline 1 main
Is this correct?
