Author Topic: TTRS 362mm Set Up  (Read 1681 times)
Offline KieranM
TTRS 362mm Set Up
« on: May 10, 2016, 10:30:51 pm »
I'm looking at getting a 362mm 2 piece disc set up from Reyland rather than AP seen as they are a fraction of the price of the APs! Are you able to use the standard carriers from the TTRS calipers or are adaptors needed? If so what ones are available?
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=28g42rd206252j6ap91o1bvn2u&/topic,19740.0.html
Re: TTRS 362mm Set Up
« Reply #1 on: May 11, 2016, 07:23:52 am »
You'll need adapters.
Offline KieranM
« Reply #2 on: May 11, 2016, 08:33:34 am »
Would 370mm rotors and bells work without adaptors?
Offline tommygti
  • -Given: 22
« Reply #3 on: May 11, 2016, 09:20:09 am »
I have already spoken to Reyland about this a couple of months ago. If you send them the calipers and carriers (even better, a hub aswell) they can use them to measure and machine custom bells and then match the rotors for your requirements. I think they quoted me around £500.
« Reply #4 on: May 11, 2016, 09:22:28 am »
370mm ttrs rotors yes.
370 2 piece. Probably not
Offline KieranM
« Reply #5 on: May 11, 2016, 09:44:10 am »
Did you not go ahead with it in the end? Yeah I was expecting it too be around that, if they can make 370mm disc and rotors that are able to run without adaptors isn't that bad a price!
Offline tommygti
  • -Given: 22
« Reply #6 on: May 11, 2016, 02:59:56 pm »
No as I have bought 2 more sets of different calipers since inquiring, haha. I'm very indecisive. Ive finally found a setup i'm happy with so I'm sticking with it now. I will be getting Reyland to machine some custom replacement rotors at some point.
