Author Topic: Getting stuck in gear and not going in  (Read 9383 times)
Offline Scoobykiller
« on: June 04, 2016, 07:24:03 pm »
Basically sometimes my gti gets stuck in gear and its very hard to take it out.
Sometimes it wont go in unless i turn car on/off or pump?
And sometimes bite changes like the car trys running away from me
Abd most of the time its perfect?
Is it just a matter of bleeding the clutch?
Re: Getting stuck in gear and not going in
« Reply #1 on: June 04, 2016, 07:57:53 pm »
Also when i say it bites low its when my pedals on floor car creeps
But otherwise 80% time its fine
« Reply #2 on: June 04, 2016, 08:25:45 pm »
Also my car makes a noise when setting off like a takkk noise
Maybe a mounting shot aswell am thinking dogbone
Surely cant be related
All other mounts are bfi uprated
Offline vag
« Reply #3 on: June 10, 2016, 03:52:47 pm »
Input shaft end bearing spinning in the case, causes end float int he shaft. tell tail signs the clutch pedal move on its own when your foot is slightly resting on it when feathering  the throttle slightly.
 Presuming its a early gti 6 speed? the later boxes they modified the bearing to have a flat so it cant physically spin any more.
« Reply #4 on: June 11, 2016, 11:33:16 pm »
Yes its a 54 model
I been told its pressure plate?
Thing is all these symptoms only happen sometimes not all time not all the way through a drive
What you reckon best thing to do is
I dont understand what you mean about pedal moving on its own?
Offline Ricky123
  • -Receive: 27
« Reply #5 on: June 12, 2016, 11:26:03 pm »
I'd start with the cheapest options first:
Clean/lubricate gear linkage/cables
Reset your gear cables - there's a guide somewhere on how to do this (very easy)
Bleed the clutch and make sure you get all the old fluid out
Change gearbox oil - use genuine vw oil only
No point in pulling the box off and replacing it and or changing the clutch before trying the cheaper and easier options first.
59 red mk6 GTi 5dr
57 mk5 1.9 TDi match
« Reply #6 on: June 13, 2016, 05:22:37 am »
Okay i see but just wondering if non of the above fix the issue then wont know if its the box or oressure plate
Arrghh nightmare
Offline vag
« Reply #7 on: June 13, 2016, 09:06:03 pm »
Obviously try the above first, you don't have to remove the box to do a temp repair if the input shaft is moving. you can pop the black cap off which reveals the bearing and circlip which you can shim to take the play.
« Reply #8 on: June 14, 2016, 02:13:23 am »
And if that is the problem whats the permanant fix
I been told by many its the clutch :slap:
« Reply #9 on: June 14, 2016, 07:39:34 pm »
I been reading up on this and you are correct but this is for 02m boxes not 02q boxes so the shim wont work heres the part numbers
WHT-001-976
02M-301-211-B
Offline vag
« Reply #10 on: June 15, 2016, 09:07:22 pm »
Early 02Q gearboxes suffer with this as i done it to my own 05 gti last month and numerous early 3c Passats, usually you can get away with a shim
Offline GTIEagles
« Reply #11 on: September 06, 2017, 11:27:43 am »
Hi @vag, I have a 05 GTI and I'm wondering if mine might be affected too. When you added the shim was there already a shim in place or like the 02M boxes was it just a snap ring?
Offline vag
« Reply #12 on: September 10, 2017, 07:22:12 pm »
No shim just a snap ring, 1 shim is usually enough. My one was so bad i managed to put 2 shims!
