Author Topic: Tyres  (Read 2326 times)
Offline CarlW
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,92229.msg927100.html#msg927100
Tyres
« on: June 14, 2016, 08:13:23 pm »
Im looking to upgrade my current 17's to 18's.
I have a couple of queries as to what tyre setup people are running in terms of running 225/40/18 or something different like 215/40/18? Am I right in thinking that the latter would give slightly more stretch over an 8J wheel? What other differences can i expect in terms of price or anything else? Is there any other sizes that are better suited to an 18" 8J wheel instead of the 215/40/18.
The reason I am looking at changing from the typical 225/40/18 size is that I would like to make sure that i will have no rubbing when I come to lower the car more... I'd say enough to get a little finger between top of the arch and top of tyre.
Another query is which tyre to go for as i know there has been the new michelin PS4 and GYEF1 Asy 3 have been released.
Is anyone running either of the above tyres or has anyone experienced both by any chance? If so, what was your verdict?
Is the PS4 much more superior? If so, why? as from a quick search I have found a £10-£15 price difference between these two tyres for 225/40/18
Is there any other contenders i should look at?
Pilot Super Sports are a out of my price margin at the price of £115 a pop. again that price is for 225/40/18 as I seem to be struggling to get prices for either tyre in 215/40/18
« Last Edit: June 14, 2016, 08:34:13 pm by CarlW »
Offline jhook661
  • -Receive: 20
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,98678.0.html
Re: Tyres
« Reply #1 on: June 14, 2016, 08:48:31 pm »
Hi Carl
I'm running KW V1 coil-overs with one finger gap between the arch and there is barely any rubbing on 18"/8" wheels but I'm running super pro adjustable ball joint which gives me 2.0 degrees negative camber to help clear the arch also the arch mod would help a lot too
And I'm running ps4 there very good best tyre I've used so far haven't used pss though hope this helps  :happy2:
Modded Golf gti CDL engine TTE420 turbo
Rtech 440bhp 429ftlb
Offline CarlW
Re: Tyres
« Reply #2 on: June 14, 2016, 09:13:35 pm »
Hi Carl
Is this with 225/40/18 tyres also?
Offline jhook661
  • -Receive: 20
Re: Tyres
« Reply #3 on: June 14, 2016, 09:53:16 pm »
It is indeed
Re: Tyres
« Reply #4 on: June 15, 2016, 12:19:57 am »
When i was running the r32 alloys on mine with 225/40/18 with no problems
« Last Edit: June 15, 2016, 12:23:26 am by maxitrol »
Offline xjay1337
  • -Receive: 377
Re: Tyres
« Reply #5 on: June 15, 2016, 12:32:32 am »
None of this takes into account the offset of the wheel which is what ultimately matters...
Offline CarlW
Re: Tyres
« Reply #6 on: June 15, 2016, 01:12:44 am »
Offset of the wheels I'm looking at buying are ET45 so are quite tucked in still like OEM wheels
Offline jhook661
  • -Receive: 20
Re: Tyres
« Reply #7 on: June 15, 2016, 06:15:17 am »
Forgot about that part  :signLOL: et42 on mine and sits nicely
