Author Topic: Skyline mod question  (Read 5853 times)
Offline K9
  • VW LifeStyle
« on: June 21, 2016, 07:01:23 pm »
hey, does anyone do the skyline mod shown in this page http://www.golfmkv.com/forums/showthread.php?t=42586&page=44 on post #960?
need some advices from someone who have done it thx :)
Offline JoeDarKa
  • -Given: 57
  • -Receive: 74
Re: Skyline mod question
« Reply #1 on: June 21, 2016, 07:03:28 pm »
I did it ages ago and it looked pants
Offline K9
  • VW LifeStyle
« Reply #2 on: June 21, 2016, 07:13:16 pm »
how come? pics? how did you secure the bulb when drilled the hole?
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #3 on: June 21, 2016, 07:45:28 pm »
The bulb style doesn't look as good as the rings K9
Offline K9
  • VW LifeStyle
« Reply #4 on: June 21, 2016, 07:51:52 pm »
what rings do i need to use?
Offline MateyGuv
  • -Given: 32
  • -Receive: 67
  • Instagram & YouTube - mateyguv
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,69555.0.html
« Reply #5 on: June 21, 2016, 09:27:31 pm »
First pic on this link is what 90mm LED Angel eye rings look like http://www.mk5golfgti.co.uk/forum/index.php/topic,69555.45.html
Iv been working on this mod for a while and come up quite a few issues that I wasn't happy with but found solutions for most of them. Still working out the final problem but life has caught up with me so it's on the back burner for a while
Offline K9
  • VW LifeStyle
« Reply #6 on: June 21, 2016, 11:37:46 pm »
What problems do you have?
Skickat från min SM-G935F via Tapatalk
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #7 on: June 21, 2016, 11:39:38 pm »
I sent you the link and nw MateyGuv has sent the same.
Offline MateyGuv
  • -Given: 32
  • -Receive: 67
« Reply #8 on: June 22, 2016, 12:22:31 am »
Depending on what you'll accept on your car will depend if the issues Iv had will concern you but some if my problems were...
Finished look after taking the lens off, colour match of outer and inners, half brake to full circle brake to quad brake, heat issues with wiring, resistance with wiring, bulb out warning light, colour warmth of inners, dark/light spots in inners, electronics, clean power supply to LED's etc etc. I didn't want an it'll do set up so kept going to what I have now. Find me on Instagram and Youtube under the same username as there is quite a lot of info there.
If your desperate for quad lights there is a chap on Facebook who is using my first method that'll take some money from you to do a version of the skyline mod.
Just saying ---> https://instagram.com/p/BBdRFlUL938/
Offline K9
  • VW LifeStyle
« Reply #9 on: June 22, 2016, 08:54:38 am »
I want to try to wire up 2 w5w bulbs inro the housing first. But unsure that do i need a resistor or not? And should ibdrill a hole just big enough for the bulb to fit into it and the glue it there? And whwre can i take power for them to turn on with the ingnition?
Offline MateyGuv
  • -Given: 32
  • -Receive: 67
« Reply #10 on: June 22, 2016, 11:23:07 am »
Fitting bulbs is a waste of time in my opinion as it looks very very different to the outers. I didn't even try that method as Iv seen them and I didn't like the end result. @JoeDarKa has tried that method so he may be able to assist  :happy2:
Offline cenobytez
« Reply #11 on: June 22, 2016, 12:32:19 pm »
there is a guy on facebook who does the mod, he sends you out a set of lights with LED rings fitted with wires out the back, look for Mk5 golf skyline modded lights. Ric is the guys name
Offline JoeDarKa
  • -Given: 57
  • -Receive: 74
« Reply #12 on: June 22, 2016, 12:35:33 pm »
If you just put 2 bulbs in, you will get 2 very obvious bright spots with darker spots too. It looks rubbish.
Offline JoeDarKa
  • -Given: 57
  • -Receive: 74
« Reply #13 on: June 22, 2016, 12:41:17 pm »
http://www.mk5golfgti.co.uk/forum/index.php/topic,30209.420.html
I also had to cut away part of the metal in the boot so i definitely wouldnt bother! I had the skyline rings but they kept steaming up whilst cleaning it so went back to standard
Offline cenobytez
« Reply #14 on: June 22, 2016, 12:53:11 pm »
yeah, thats why you need the LED rings...
