Author Topic: Which hid kit?  (Read 8801 times)
Offline RedGolfDom
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,99951.0.html
Which hid kit?
« on: June 28, 2016, 03:57:48 pm »
Which hid kit is the best to go for? Ordered some depo projector headlights so need some for them.  Also looking around some are 35w and others 55w which is the one I need?
Mk5 golf gt 140
Revo stage 1
Air lift Performance 3p
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
Re: Which hid kit?
« Reply #1 on: June 28, 2016, 04:10:18 pm »
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
Re: Which hid kit?
« Reply #2 on: June 28, 2016, 04:10:46 pm »
H7,  metal base
Offline RedGolfDom
Re: Which hid kit?
« Reply #3 on: June 28, 2016, 06:22:41 pm »
Cheers mate, which colour temp did you go for?
Mk5 golf gt 140
Revo stage 1
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
Re: Which hid kit?
« Reply #4 on: June 28, 2016, 06:26:05 pm »
I went for 5000k . anything higher will start going more blue and less visibility on road.
Offline RedGolfDom
Re: Which hid kit?
« Reply #5 on: June 28, 2016, 06:37:45 pm »
Cheers mate I'll get them ordered then!  :happy2:
Mk5 golf gt 140
Revo stage 1
Offline Adam0604
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,97534.0.html
Re: Which hid kit?
« Reply #6 on: June 28, 2016, 06:45:42 pm »
Daft question, but where did you put all the wiring / the square bits?
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
Re: Which hid kit?
« Reply #7 on: June 28, 2016, 07:44:10 pm »
The ballast i screwed underneath the headlamps, the wires and the other square bits I managed to push down and also place towards the bottom of the headlamps.
Offline Adam0604
Re: Which hid kit?
« Reply #8 on: June 28, 2016, 07:45:06 pm »
Thanks man, going to order these now
Offline An0NyMOUs
  • A Nuisance
Re: Which hid kit?
« Reply #9 on: June 28, 2016, 07:55:01 pm »
Personally I'd go for a 55w 5000k kit as it'll be a bit brighter
2.0 FSI 4motion
Offline RedGolfDom
Re: Which hid kit?
« Reply #10 on: June 29, 2016, 12:14:48 am »
Heard something about power drain with coming home lights on is this a common issue?
Mk5 golf gt 140
Revo stage 1
Offline r5gtt
  • -Given: 342
  • -Receive: 334
Re: Which hid kit?
« Reply #11 on: June 29, 2016, 01:01:15 am »
55w have been on my car over 5 months probably longer as I've lost count and I've got coming home lights switched on with no issues with power drain  :happy2:
Offline akbarirfan
  • -Given: 81
Re: Which hid kit?
« Reply #12 on: June 29, 2016, 12:34:45 pm »
Same as above, 55w Kit with no power drain issues.
Offline RedGolfDom
Re: Which hid kit?
« Reply #13 on: June 29, 2016, 02:38:24 pm »
Thanks guys, @r5gtt what bulb setup do you use for the full orange strip? I have vcds so can code in the indicators
Mk5 golf gt 140
Revo stage 1
Offline bad devotions
  • -Given: 19
Re: Which hid kit?
« Reply #14 on: June 29, 2016, 02:41:16 pm »
i ended up going for the metal base h7 35w ones at around 5000k. I did the 6 oclock mod though which was fun with the metal.
