Author Topic: Show me your boost gauges!  (Read 14263 times)
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
« on: July 20, 2016, 03:38:28 pm »
Anybody out there able to recommend a boost gauge they've fitted to their GTI?
  • -Receive: 427
Re: Show me your boost gauges!
« Reply #1 on: July 20, 2016, 04:42:21 pm »
Newsouth indigo. Had mine for years and was great (had mine in vent pod). Lights up OEM in colour at nighttime plus helps to see if there are any boost related problems at a glance.
Defi Boost gauge if you want to spend more and P3 if your after a digital one.
Awesome GTI sell Newsouth.
Offline AJP
  • -Given: 392
  • -Receive: 316
« Reply #2 on: July 20, 2016, 06:04:32 pm »
Is the boost readout on Polar FIS adequate for keeping an eye on things?
Or would a proper needle be better?
Offline dubvrs
« Reply #3 on: July 20, 2016, 06:06:41 pm »
Have the new south indigo for boost and polar FIS for temps etc.
Offline AJP
  • -Given: 392
  • -Receive: 316
« Reply #4 on: July 20, 2016, 06:24:09 pm »
Nice. Can't deny a proper boost gauge is a cool thing anyway :)
dansmith180
« Reply #5 on: July 20, 2016, 07:41:11 pm »
From what I've hear the boost on Polar is requested and not actual as there's no factory sensor but I could be talking sh*t.
Offline AJP
  • -Given: 392
  • -Receive: 316
« Reply #6 on: July 20, 2016, 07:52:01 pm »
That'd make sense, as normal gauges use a boost tap rather than an existing sensor. Although you can log requested against actual in VCDS can't you... so I'm not sure? I may also be talking dogsheet :)
Offline Spankiee
  • -Receive: 20
« Reply #7 on: July 20, 2016, 08:45:48 pm »
check out PSI tuning website they have several OEM looking options available.
candy white edition 30
Offline th3_f15t
  • -Receive: 183
« Reply #8 on: July 20, 2016, 10:48:56 pm »
Wouldn't the ECU work out boost pressure using the manifold air pressure (MAP) sensor? That would be a way of the PolarFIS being able to display both requested and "actual" (as a calculation of ambient air pressure taken from MAP reading). Just a guess though...
Offline horsemeat
« Reply #9 on: July 21, 2016, 12:24:35 pm »
Polar fis apparently displays both "actual" and "requested" parameters. I've no idea how it's accomplished. Seems to peak at around 11 on my stock k03 which is about right iirc.
The readout isn't very smooth, a dedicated gauge would be nicer for sure. I like dubvrs' setup.
« Last Edit: July 21, 2016, 12:27:00 pm by horsemeat »
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
« Reply #10 on: July 21, 2016, 12:52:15 pm »
Think I'll go with the P3 down the line. I missed out on one for sale here but I'm sure I'll pick one up!
strothow
« Reply #11 on: July 21, 2016, 01:09:18 pm »
I had one on mine when i bought it, don't want it, welcome to it if you want?
Its a complete replacement to the vent.
Offline Matto
  • -Receive: 116
« Reply #12 on: July 21, 2016, 05:52:09 pm »
Not sure on the petrol ECU's but there is one limitation with Polar FIS, well it actually lies within the ECU when it comes to boost. It does with the Siemens ECU anyway. It is able to read figures higher than 1.6 Bar but cannot display them. If you log boost in VCDS, it will go off the chart at 2.6 bar (1 Bar atmosphere + 1.6 Bar boost). This also happens on the Polar. Mine maxes out at 1.66 Bar. My map is set to peak at 1.75 which I cannot see without a mechanical gauge.
Here is my gauge. Also Newsouth Indigo.
Offline oak_grun
« Reply #13 on: July 21, 2016, 06:31:20 pm »
Will be getting a new south vent gauge shortly.
Looks like a proper little cockpick that pic! :driver:
Offline jaffa
  • -Receive: 44
« Reply #14 on: July 21, 2016, 07:56:27 pm »
Iv got a p3cars in my car but for some reason it slowly drains my battery, probably doesn't help I only use the car once a week
It is a great bit of kit tho im assuming that because my car is an 05 has something to do with the drain
