Author Topic: Brake upgrade?  (Read 1894 times)
MPS
Brake upgrade?
« on: July 23, 2016, 07:32:53 pm »
Can you upgrade just the front brakes or would it upset the balance? I was thinking of fitting r32 or possibly mk7 Performance Pack front brakes to my mk5.
Offline dronners
Re: Brake upgrade?
« Reply #1 on: July 23, 2016, 09:07:52 pm »
as long as the front brakes are bigger than the rears you'll get the brake bias in good favour
Offline AJP
  • -Given: 392
  • -Receive: 316
Re: Brake upgrade?
« Reply #2 on: July 23, 2016, 09:35:03 pm »
In an ideal world you'd fit 310mm R32/S3 rears as well - some people report the back end feeling a bit light under heavy braking with upgraded fronts and standard rears. Although they're apparently quite hard to get hold of.
  • -Receive: 427
Re: Brake upgrade?
« Reply #3 on: July 23, 2016, 09:45:01 pm »
Before I fitted bigger brakes to the rear (S3 calipers and discs) on my Stage 2+ Eddy a few times while under VERY heavy breaking the car definelty felt unbalanced. Once fitted the car felt slightly more planted. 90% of the time I could tell no difference.
Offline doylebros
Re: Brake upgrade?
« Reply #4 on: July 23, 2016, 09:50:04 pm »
Now there's a honest answer cause most people wouldn't apprise an item they've paid good money for other the typical quote "yer there the dogs bollicks".
Offline grey golfster
  • -Given: 79
Re: Brake upgrade?
« Reply #5 on: July 24, 2016, 07:46:47 am »
I'm no expert.
Have a look at these tech paper from Stoptech US.
http://www.stoptech.com/technical-support/technical-white-papers/white-paper---brake-bias-and-performance-why-brake-balance-matters
and
http://www.stoptech.com/technical-support/technical-white-papers/rear-brake-upgrades
Declaration of interest - I have Stoptech ST41 Front BBK only on my Stg 2 Eddy; works well for me, but I don't track.
Re: Brake upgrade?
« Reply #6 on: July 24, 2016, 08:33:37 am »
There's "some" nonsense in that last stop tech link and lots of marketing and sales "guff"
I've got 362mm front brakes and 282mm rears. Never had an issue with brake bias.
Offline Flyingscotsman
Re: Brake upgrade?
« Reply #7 on: July 24, 2016, 02:22:18 pm »
Can anyone tell me if the front calipers from Mk7 Golf R & the 340mm disks are a direct swap without brackets or spacers to the Mk5 (with Monza 2s) as an alternative to the R32/S3 upgrade?
Thanks in advance  :smiley:
