Author Topic: when I press brakes my radio frequency goes fuzzy  (Read 4616 times)
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« on: September 04, 2016, 11:05:17 pm »
Been having this problem sinse I've been driving this car and it just doesn't go fuzzy but also no music from speakers. Any idea guys?.
btw it's an rds300
« Last Edit: September 04, 2016, 11:29:05 pm by r5gtt »
Offline r5gtt
  • -Given: 342
  • -Receive: 334
Re: when I press brakes my radio frequency goes fuzzy
« Reply #1 on: September 05, 2016, 08:58:40 pm »
Anyone?.  :sad1:
Offline flashp
  • -Receive: 65
« Reply #2 on: September 05, 2016, 10:10:41 pm »
Aerial lead caught behind pedal mechanism and damaged coax maybe? Can't imagine how it could be caused by an electrical fault but not an expert, could be a supply problem to an amplifier relating to common supplies?. Maybe try a cheap mag mount aerial with its own coax.
Gone but not forgotten :-)
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #3 on: September 05, 2016, 10:56:39 pm »
Cheers @flashp I'll check the pedal area out as it's doing my head in as I come.to a slow down or stop and it's hissing at me  :doh: people might think I'm mad listening to a hiss  :stupid: if I can't find a solution it'll be out the window and new set up in.
Offline Flyingscotsman
« Reply #4 on: September 06, 2016, 02:06:49 pm »
Do you have fancy brake lights (eg LEDs), it's possible that LEDs or associated electronics might generate radio frequency noise.
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
« Reply #5 on: September 06, 2016, 04:00:55 pm »
If you're stationary and you press the brake does it still make the noise?
Or is it only when you brake hard whilst driving?
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #6 on: September 06, 2016, 07:01:26 pm »
Oh noooooooo  :scared: I think it started after I fitted the inner skyline lights but can't be 100% sure as I didn't really listen to the radio then.
Yes it's the same when I'm stationery or braking and slowing down not sure about when braking hard.
« Reply #7 on: September 06, 2016, 09:13:41 pm »
Sounds like RF noise from your fancy brake lights
Offline slix
  • -Receive: 38
  • Stage 1 ED30 Owner
« Reply #8 on: September 06, 2016, 09:54:57 pm »
Maybe try and fit a shielding around the lights.  That may help.
Stage "1.5" ED30 [330BHP] Rtech
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #9 on: September 06, 2016, 10:07:05 pm »
:doh: thank mate  :drinking:
cheers I'll give that a go when I get a chance  :drinking:
« Reply #10 on: September 06, 2016, 10:14:50 pm »
It's definitely interference some where,unplug your lighting and go from there
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #11 on: September 06, 2016, 10:31:31 pm »
unplug  :thinking: that'll be quite difficult as all the wiring plugs are hidden away in the boot lid.
Will need to cut the wiring at the connections behind the rear panels  :sad1:
Thanks mate
dansmith180
« Reply #12 on: September 07, 2016, 08:10:44 am »
You can unplug the main two rear lights in 5 seconds. Just move the felt lining and you'll see a plug going into each unit, push a flathead screwdriver towards the front of the car and boom.
« Reply #13 on: September 07, 2016, 09:19:46 am »
Just pull the fuses for the lights
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
« Reply #14 on: September 07, 2016, 09:59:06 am »
He did the skyline mod so it's no longer that simple I think...
Fuses out!
