Author Topic: engine swap axx to bwa  (Read 1911 times)
aus
« on: September 27, 2016, 11:27:30 pm »
can i fit a bwa as the axx is beyond repair
Offline stuart-88
  • -Receive: 21
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,101197.0.html
Re: engine swap axx to bwa
« Reply #1 on: September 28, 2016, 12:53:15 pm »
Straight swap I believe. What happened to the AXX?
Instagram: stu_nc88
Offline leebes
  • When's the next track day?
  • My Ride: 2007 Mk5 Gti (Reflex Silver)
« Reply #2 on: September 28, 2016, 08:13:09 pm »
AXX and BWA are essentially the same I believe, with the BWA having a slightly lower static compression to apparently make it more reliable. BWA being the later model, but both fitted to the Mk5
Offline tarangill9
« Reply #3 on: October 06, 2016, 03:24:04 pm »
hi, it would be a straight swap also a much more reliable and stronger engine as mentioned above :drinking: good luck with the swap
