Author Topic: Mp3 and phone button  (Read 4798 times)
Offline bikergeorge
« on: October 20, 2016, 09:33:40 am »
Morning guys, I'm still playing with the new car and trying to figure out what does what. Few questions about the stereo and mfsw.
Firstly the stereo head unit has mp3 printed on it, how do I connect to it with my phone, can't find any ports anywhere.
Secondly, the phone button on the mfsw does nothing, should it?
Sent from my SM-G930F using Tapatalk
Offline Kai96
Re: Mp3 and phone button
« Reply #1 on: October 20, 2016, 10:00:16 am »
Same as mine I'd be interested in the answers. Me and my sister have the same headunit (she has a mk6), but when she clicks phone it comes up with a set of options and she can connect her phone to it. Mine just mutes my music  :signLOL:
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #2 on: October 20, 2016, 10:03:30 am »
You need a Bluetooth module as your car wouldn't have come with one factory fitted
Offline bikergeorge
« Reply #3 on: October 20, 2016, 02:33:58 pm »
Is there an easier way to get music, can you retrofit a USB port or a headphone jack
Offline bikergeorge
« Reply #4 on: October 20, 2016, 02:34:20 pm »
Is there an easier way to get music, can you retrofit a USB port or a headphone jack to the original head unit
Offline mk5Eire
« Reply #5 on: October 20, 2016, 02:43:12 pm »
You have loads of options.
Firstly you could upgrade your headunit to an aftermarket one with usb/aux/sd card functions or to something oem like an rns510 or rcd510 which have an sd card slot and i think you can plug an aux cable into the back of them too.
you could purchase an mdi kit from vw which can go in the glovebox or armrest this will give you full control of media connected from your device through your radio. There are also loads of boxes like the connects 2 that plug into the cd changer slot and have ports for usb and aux. Again you can bring these out into the glovebox which is the tidiest place and out of sight.
Give a quick search, something like "adding usb or aux to rcd 300", you will find loads of information.
Best of luck
Offline bikergeorge
« Reply #6 on: October 20, 2016, 07:29:45 pm »
Look at this on eBay  http://www.ebay.co.uk/itm/351256547092
Would this work, seems ok
Offline mk5Eire
« Reply #7 on: October 20, 2016, 10:02:13 pm »
On the European rcd510 there is no USB connection at the back of the radio. The Chinese models do but they do not have rds.
If you plan on keeping your standard radio I'd look into this
Look at this on eBay  http://www.ebay.co.uk/itm/181256596185
I had one in my old mk5 gti. Worked very well.
Offline bikergeorge
« Reply #8 on: October 24, 2016, 02:14:05 pm »
Just got a 3.5 Jack lead for my rcd300 plugged it all in, how do I activate the aux function to get the phone to play, cheers
Offline AJP
  • -Given: 392
  • -Receive: 316
« Reply #9 on: October 24, 2016, 03:54:04 pm »
I think you need to press the CD button twice
Offline bikergeorge
« Reply #10 on: October 24, 2016, 10:50:38 pm »
Found out that the head unit won't work with just the leader, you need the module to go with them
« Reply #11 on: October 25, 2016, 07:52:11 am »
IIRC mp3 refers to mp3 CDs ie you could burn hundreds of mp3s to CD and it'll play them as opposed to having to burn as an audio CD and having only 10-12 tracks.
Only if you have bluetooth fitted.
Offline bikergeorge
« Reply #12 on: October 25, 2016, 08:36:07 am »
Look at this on eBay  http://www.ebay.co.uk/itm/121545513649
Bought one of these, should do it all I hope
