Author Topic: Aerial adapter from RDC300 to RCD510/RNS510  (Read 6968 times)
Offline holty
  • -Given: 17
« on: January 23, 2010, 09:26:57 pm »
Hey
Just fitted an RCD510 this afternoon, i have noticed the aerial connection is slightly different (the rcd300 is slightly wider) - do people cut the plastic to make it fit or is there an adapter? My signal isnt really good after the fitting!
Offline ollie288
Re: Aerial adapter from RDC300 to RCD510/RNS510
« Reply #1 on: January 23, 2010, 09:37:49 pm »
There is an adapter that can be purchased. You can get it from VW, ebay etc. Mortygttdi may be able to sort you out with one of here.
Did you make sure you but the leads the correct way? Made a little difference on mine!  :happy2:
Offline holty
  • -Given: 17
« Reply #2 on: January 23, 2010, 09:53:52 pm »
any links to ebay fella? cant see one. :happy2:
Offline ollie288
Offline holty
  • -Given: 17
« Reply #4 on: January 23, 2010, 10:33:23 pm »
Hero! Cheers will pop down to vw next week! Need some center caps too.
Offline ollie288
« Reply #5 on: January 23, 2010, 10:39:33 pm »
http://cgi.ebay.co.uk/VW-Monza-Alloy-Wheel-Centre-Cap-MK5-Golf-GTI_W0QQitemZ400089979593QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item5d27389ac9#ht_500wt_956
Not sure if they will be more than this from VW. You have a price to go by. Maybe some cheaper ones on the bay to!  :happy2:
Nasir
« Reply #6 on: January 23, 2010, 10:42:56 pm »
The caps are cheaper at VW :happy2:
Offline QD MBE
  • -Receive: 102
« Reply #7 on: January 23, 2010, 10:49:13 pm »
Don't need an adapter, there is a way of sorting it.
http://www.mk5golfgti.co.uk/forum/index.php?topic=10743.0
cameluk
« Reply #8 on: January 23, 2010, 11:12:59 pm »
7L6051551, about £22 from the dealer
Offline R32 mad
« Reply #9 on: September 09, 2010, 08:58:08 pm »
Does the ends of the cable with the biege and white connectors connect to the white block connectors coming from the dash? If it is then your option is cheaper as opposed to this I found, also genuine VW parts. I assume the cable you fitted doesn't need the pink/blue adaptor shown below.
Or do you have to order these two parts:
Part numbers are:
4E0 035 608 K - £2.30* (Adaptor)
000 098 707 (you will need 2 of these) - £14.46* each  (Cables)
« Last Edit: September 09, 2010, 09:15:20 pm by R32 mad »
