April 16, 2025, 04:54:32 pm
All Things Mk5
Mk5 General Area
TDI Brakes?
Topic: TDI Brakes? (Read 1248 times)
Hendry
Always Involved
-Given: 0
-Receive: 0
TDI Brakes?
November 16, 2016, 02:59:32 am »
Couple of quick questions guys:
I've got a 2009 Jetta 2.0 CR TDi 140bhp Sport and want to know what size the standard front brake discs are as I want to upgrade to GTi 312mm discs and pads and I've been reading that cars with standard 288mm discs can use the original calipers when upgrading as they share the same calipers as the GTi whereas cars with 280mm discs need the calipers changing as they run different ones.
Secondly, what discs do I actually need, checked the VW TPS website and there's 3 different discs listed for the mk5 with 2.0 TFSI 200bhp engine.
https://tps.trade/part/braking/brake-disc
Shoduchi
Just look at my post count
-Given: 220
-Receive: 429
My Ride:
Re: TDI Brakes?
Reply #1 on:
November 16, 2016, 12:04:11 pm »
You need GTI calipers brackets and 312 mm discs with part number starting with 1K0.
Silver Reflex Mk5 Golf GT Sport
.:R-Line
1.9 TDI 105@171PS 5 Doors
Candy White Mk5 Golf GTI Edition 30 DSG 230@409PS 3 Doors
RetroRaz
-Given: 32
-Receive: 194
Re: TDI Brakes?
Reply #2 on:
November 16, 2016, 12:20:25 pm »
I will have my front GTI brake setup for sale soon if youre interested?, Discs, pads, calipers, caliper carriers and hoses
#RetroRaz -
https://instagram.com/retroraz/
Hendry
Always Involved
-Given: 0
-Receive: 0
Re: TDI Brakes?
Reply #3 on:
November 17, 2016, 03:58:24 am »
Won't my existing calipers be the same if I have standard 288mm discs which I believe I should have with having the 2.0 CR TDi 140bhp engine?
Dan_FR
-Given: 132
-Receive: 189
wait...what?
Re: TDI Brakes?
Reply #4 on:
November 17, 2016, 08:27:50 am »
A 30 second search on google would tell you exactly what you need to know:
http://www.mk5golfgti.co.uk/forum/index.php?topic=45948.0
http://www.mk5golfgti.co.uk/forum/index.php/topic,35049.msg500000.html#msg500000
http://www.vwaudiforum.co.uk/forum/showthread.php/113972-Brake-upgrade-288mm-to-312mm
Funnily enough i removed my 312mm set up last week to fit the 345mm S3 upgrade. You should find a pair of carriers without issue
Last Edit: November 17, 2016, 08:45:13 am by Dan_FR
TFSI... Revo Stage 2+... . WMI.... VCDS HEX + CAN, MPPS, VAG Commander & VAG tacho - South Wales
All Things Mk5
Mk5 General Area
TDI Brakes?
Jump to:
=> Mk5 General Area
