Author Topic: Cam Chain Tensioner?? Ed30 ???  (Read 7209 times)
Charlie23
« on: November 17, 2016, 10:26:18 am »
Hi Guys,
Just rang VW as my Ed 30 is up on 95k so wanted to get the Cam chain adjusted and im no expert but they are telling me there are 2 different engines and mine has a belt not a chain?? I know this is correct as i have had the belt etc changed but do the Ed30's suffer from this and have the same set up as the standard GTi?
Told me i dont need it done??
« Last Edit: November 17, 2016, 11:04:38 am by Charlie23 »
Re: Cam Chain Tensioner??
« Reply #1 on: November 17, 2016, 10:29:10 am »
Why do you want it adjusted?
Charlie23
« Reply #2 on: November 17, 2016, 10:33:23 am »
On cold start up i heard a slight little rattle so for the sake of a few £££ (plus im fussy) get it checked and adjusted if needed.
  • -Receive: 690
« Reply #3 on: November 17, 2016, 11:05:24 am »
TFSI EA113 = Belt + chain.
TSI EA888 = Chain only.
There is no adjustment you can make, it's self regulated by the hydraulic tensioner.
The typical symptom of worn chain gear on the GTI/ED30/Pirelli is a diesel clattering noise inside the cabin (windows up) when hot idling.   If you hear this, the only cure is to replace the cam chain and the tensioner, which I'm afraid is considerably more than a few ££s.
I had to that on my ED30 around that mileage.
Charlie23
Re: Cam Chain Tensioner?? Ed30 ???
« Reply #4 on: November 17, 2016, 11:19:22 am »
Cheers for that Pudding make it alot more clear now  :happy2:
i dont mind paying to get it done as that part of the maintenace when these miles come up but i was abit unsure of the process and what was needed.
Thanks again
  • -Receive: 690
« Reply #5 on: November 17, 2016, 12:11:50 pm »
Good man  :smiley:
It's not too bad a job DIY if you're competent with the spanners, and the parts are around £200 if I remember correctly. You also need a special tool to lock the cams together when cracking off the exhaust cam sprocket/VVT adjuster bolt.
Probably £800ish at a dealer, £400-£500 at an indy as rough ball parks.
Charlie23
« Reply #6 on: November 23, 2016, 04:53:11 pm »
Found a  VW mechanic that is going to do this for me over the weekend  :happy2:
Would any one know the part numbers/ parts i need to order ? Chain, tensioners etc etc  :thinking:
Thanks in advance
  • -Receive: 690
« Reply #7 on: November 23, 2016, 04:56:16 pm »
Try a search mate, someone listed the parts out not long ago.
How come you went from an S3 to an ED30?  Just curious as I'm thinking of going the other way, lol!
Offline f00glee
« Reply #8 on: November 23, 2016, 08:52:38 pm »
Cam Chain   06D 109 229 B
Chain Tensioner   06F 109 217 A
Cam Cover Gasket   06F 103 483 D
Adjuster Bolt   06D 109 281 D
Chain Cover Gasket   06D 103 121 B
Tensioner Bolts (3)   N-101-963-03
Chain Cover Bolts (7)   N-101-243-08
Hose Clip   N-907-399-01
Seal   06E127248
Thats the parts for a standard GTI. If they're the same required on an ED30 - that's all you'll need.  :happy2:
Current:
Mk6 R, Tornado Red, 5-door, '13.
Previous:
Mk5 GTI, Tornado Red, 3-door, '06, R-tech Stage "1+"
Charlie23
« Reply #9 on: November 24, 2016, 04:08:27 pm »
I didnt go direct from S3 to and Edition 30 haha. I had a 57 Plate S3 stage 2+ then A Range Rover Sport, then back to a 09 Plate S3 (facelift) then Porsche 911 then to the Ed30 haha  :doh:
But the question you want to know is what is better lol. Being totlay honest the S3 is a better car if your going for power due to the 4wd geting the power down, and the only other plus side is the Bose sound system, but bar that its vertualy the same as the Ed30.
The big diffrence realy is the Price's.
DSG S3 are £12k+ as all facelift where as the Ed30 DSG £7k+
Hope that helps a little.
But one of my regrets is selling my stage 2+ S3 as that was an absolute weapon  :happy2:
Charlie23
« Reply #10 on: November 24, 2016, 04:09:38 pm »
Seal   06E127248
Cheers mate, im sure the Ed30's are different, but correct me if im wrong (sorry)
Offline dronners
« Reply #11 on: November 24, 2016, 04:14:57 pm »
edition 30 engine components are 99% all the same.  course there are a few differences here and there. fairly confident the chain system would be the same though
  • -Receive: 690
« Reply #12 on: November 24, 2016, 04:24:12 pm »
Cheers mate!
My only regret when buying my Ed30 was getting a manual, otherwise it has a good spec.  I'm bored of changing gears and the heavy clutch needed for remapped power, so it's time to get into a DSG.  I'm undecided on whether to go DSG S3, or DSG Ed30!   To be honest the Ed30 is better looking to my eyes than the S3, but I know the S3 is better made inside!  Hmmm.....
Charlie23
« Reply #13 on: November 24, 2016, 04:41:33 pm »
Plus the DSG S3 is double the price of an ED30 DSG haha.
I have a DSG Ed30 buy mine if you want lol
  • -Receive: 690
« Reply #14 on: November 24, 2016, 04:48:00 pm »
I'd need to trade it in with a stealer against a DSG flavour, or swap it with someone who wants a manual, as it's my daily!
