Author Topic: Clutch Pedal Fallen To The Floor After Bleed!!  (Read 1351 times)
Offline alichowdry
« on: December 03, 2016, 07:16:56 pm »
Hi people of the forum!
So I was set out to do an abs pump replacement, so far so good, managed to get the replacement abs pump in and I was about to start bleeding the brakes and clutch, now I was following a guide on YouTube (Micks Garage).
I bled the brakes in order front left, front right, rear left and rear right until the fluid coming out was the same colour as my new fluid and had no air bubbles.
I then went to bleed the clutch, I popped off the cover, and I loosened it and fluid started to come out, I then closed the drain port/nipple and depressed the clutch 10-15 times as described in the guide. I then opened the nipple and drained another 50ml, I then closed it and when to depress the clutch a further several times as described however when I did so, the clutch pedal hit the ground and did not come back?!
What can I do about this? I have read around and apparently this means there is air in the system?
Thanks for any help!  :happy2: :happy2: :happy2:
