Author Topic: DSG Remaps  (Read 3674 times)
Offline GE90
DSG Remaps
« on: January 14, 2017, 10:43:58 pm »
Hi All
Just wondered whether any fellow forum members have had their DSG remapped?
Would appreciate any feedback on which companies offer this, and whether you've been happy with the results?! My primary reason is to smooth down changes in Drive.
I am in Bromley, Kent, so somewhere local would be good, or otherwise a handheld unit to upload appears to be an option.
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
Re: DSG Remaps
« Reply #1 on: January 14, 2017, 11:56:24 pm »
I'd do a DSG reset first. That should help a lot or that after a oil and filter change. The remap allows more torque from the engine, speeds shifts, allows an higher rpm limit and gives you more control of the gearbox.
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
Re: DSG Remaps
« Reply #2 on: January 15, 2017, 02:00:59 am »
I did one by GIAC. I like the torque limiter removal (my torque is 363 lb*ft), the higher rpm launch control, higher redline rpm (6900rpm), and that it stays in a manually selected gear longer before downshifting. I don't think I would opt for it unless stage 2+ (w/hpfp upgrade) or K04  :drinking:
Offline GE90
Re: DSG Remaps
« Reply #3 on: January 15, 2017, 01:47:25 pm »
Thanks guys. I've already done a full adaptations reset, and changed the oil and filter.
The way I look at it, if I am able to find a tuner happy to offer a refund say within 30 days if not happy, I've got nothing to lose.
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=6avqcua7e7j8p1vfp2mc57m7jh&/topic,19740.0.html
Re: DSG Remaps
« Reply #4 on: January 15, 2017, 01:55:48 pm »
If it's jerky then a remap won't fix that.
Offline P3T3R
  • 05 GTI, R-Tech stage 1
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,82245.0.html
Re: DSG Remaps
« Reply #5 on: January 15, 2017, 02:40:02 pm »
Guys at AMD (Essex) should be able to sort you out.
Offline GE90
Re: DSG Remaps
« Reply #6 on: January 15, 2017, 02:56:12 pm »
Thanks - email sent!
I wouldn't say it is jerky, just not very smooth in D when it changes from say 4th to 3rd, or 3rd to 2nd.
In all other respects, it is perfectly smooth.
Re: DSG Remaps
« Reply #7 on: January 15, 2017, 03:05:04 pm »
Remap won't help. You can waste your money on one thought if you like.
Offline slix
  • -Receive: 38
  • Stage 1 ED30 Owner
Re: DSG Remaps
« Reply #8 on: January 15, 2017, 05:29:24 pm »
This.
Will be a waste of money.  Try the other routes suggested first like a dsg reset and maybe service.
Stage "1.5" ED30 [330BHP] Rtech
Offline GE90
Re: DSG Remaps
« Reply #9 on: January 15, 2017, 06:26:59 pm »
Ah, OK, back to the drawing board as service and reset already done!
Re: DSG Remaps
« Reply #10 on: January 15, 2017, 07:11:44 pm »
New mechatronics unit it is then.... or get yours refurbished.
Offline GE90
Re: DSG Remaps
« Reply #11 on: January 15, 2017, 07:19:52 pm »
I'm not convinced. I've have experience of a new mechatronics on my previous R32.
It's under a VW used car warranty for a little longer, but dealership doesn't agree it's a fault!
Re: DSG Remaps
« Reply #12 on: January 15, 2017, 08:00:12 pm »
Without actually driving it its impossible to diagnose...
Offline GE90
Re: DSG Remaps
« Reply #13 on: January 15, 2017, 08:09:38 pm »
Yeah, you're right. It's difficult to explain.
Probably best described as far too much engine braking when no throttle applied i.e. when gently braking to a stop. When others are in the car it is quite embarrassing!
Really disappointing, as it is otherwise great!
Re: DSG Remaps
« Reply #14 on: January 15, 2017, 08:11:20 pm »
Where are you?
