Author Topic: Intermittent Turbo boost?  (Read 7879 times)
Offline jason_rmh
  • -Given: 69
  • -Receive: 81
Re: Intermittent Turbo boost?
« Reply #15 on: February 14, 2017, 07:27:46 am »
In engine module, measuring blocks.
log the following groups:
114: N75 duty cycle
115: boost (actual / expected)
Find a quiet stretch of road.
Start from a slow roll, start logging.
change to 3rd gear, accelerate to full throttle (wide open throttle).
Do a few runs then put the data into excel to make a graph and view the data.
Jas
VCDS (Preston, Lancashire)
Offline DBXdarkangel
  • -Given: 18
« Reply #16 on: February 21, 2017, 01:09:43 pm »
So I did a few runs today and ive got no idea what to make of it. Hopefully you guys can help me out.. pleeeeeaaassee
http://www.filedropper.com/log-01-114-115-xxx
not sure how to add the file here so hope the download link above works ok
« Reply #17 on: February 21, 2017, 01:16:22 pm »
You didnt log the fuel rail pressure.
Offline Pesky jones
« Reply #18 on: February 21, 2017, 01:38:07 pm »
blocks 231 are the blocks you need for fuel rail pressure - actual & specified
  • -Given: 18
« Reply #19 on: February 21, 2017, 02:01:30 pm »
Oh i just logged 114 and 115 like was mentioned.
How does the log look tho as in is it ok?
« Last Edit: February 21, 2017, 06:29:41 pm by DBXdarkangel »
  • -Given: 18
« Reply #20 on: February 22, 2017, 11:09:32 am »
Just wondering if the boost looks ok and n75 is working
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
« Reply #21 on: February 22, 2017, 06:44:33 pm »
231 is the low fuel pressure...230 is the rail/high pressure.
Going to look at your boost data today...then later...I cannot open the data?
« Last Edit: February 22, 2017, 06:50:22 pm by ROH ECHT »
  • -Given: 18
« Reply #22 on: February 23, 2017, 01:50:48 pm »
Pm me your email and will send it it mate.
  • -Given: 18
« Reply #23 on: February 25, 2017, 06:34:21 pm »
Anyone?
Offline TAPPY
  • -Receive: 56
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,103290.0.html
« Reply #24 on: February 25, 2017, 09:14:51 pm »
I have the same issue. It's fine most of the time but last week it wouldn't boost over 5 psi then 2 mins later it was back up to 11 psi then 2 days later it wouldn't go over 7 psi then same again 11 psi. I'm running a gfb DV+ so doubt that's my problem so wouldn't mind knowing what you find  :popcornsoda:
« Reply #25 on: February 27, 2017, 12:14:00 pm »
Anyone?
You are not giving us enough information.
  • -Given: 18
« Reply #26 on: February 27, 2017, 01:35:40 pm »
What you want to know?
  • -Given: 18
« Reply #27 on: March 01, 2017, 08:54:11 am »
  • -Given: 18
« Reply #28 on: March 09, 2017, 11:53:31 am »
Bump for help
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
« Reply #29 on: March 09, 2017, 01:02:03 pm »
Posting here so I can take a look at the logs tonight - can't download files in work
