Author Topic: Please help!!! Camshaft issue  (Read 2056 times)
AndyB1988
« on: March 15, 2017, 05:51:33 pm »
Just had my timing belt and pump done, and when it's come back fault code p0011 has appeared. I've had it back to the garage and they say the timing is spot on. Can anyone shed any light please????
Offline MaxC
Re: Please help!!! Camshaft issue
« Reply #1 on: March 16, 2017, 02:24:23 pm »
I've got the same problem here
Offline Vish8895
« Reply #2 on: March 16, 2017, 03:02:00 pm »
If the garage say the timing is spot on check the other two possible causes detailed on RossTech:
http://wiki.ross-tech.com/wiki/index.php/16395/P0011/000017
If they are fine, have somewhere else check the timing.
AndyB1988
« Reply #3 on: March 16, 2017, 04:24:35 pm »
Thanks that's great. They are checking the chain tomorrow so will know more soon. Thanks for the response!
Offline doylebros
« Reply #4 on: March 16, 2017, 07:01:22 pm »
Find someone with VCDS
http://www.mk5golfgti.co.uk/forum/index.php/topic,88875.0.html
Read reply#43 by Pesky Jones in this thread (I know it's the cam chain job not Tbelt)
http://www.mk5golfgti.co.uk/forum/index.php/topic,106158.30.html
Check your values match those quoted if they differ and your vehicle drove fine before your repairer touched it then I expect the cam is half tooth out.
Offline MaxC
« Reply #5 on: March 17, 2017, 07:00:26 pm »
Just checked my timing and getting 23.5-24kw.
I saw 22.5kw for a split second a few times though, might of been me blipping the throttle though
« Reply #6 on: March 17, 2017, 11:57:19 pm »
I dont understand how it could be the cam linking chain that is out. All the did was do the cambelt, they shouldnt have gone anywhere near the chain.
