April 28, 2025, 05:07:07 am
All Things Mk5
Mk5 General Area
Changing sidelight bulbs on factory xenons?
Topic: Changing sidelight bulbs on factory xenons? (Read 1215 times)
petesimcock
Always Involved
-Given: 3
-Receive: 6
April 08, 2017, 04:58:01 pm »
Hi guys, I'm having tremendous trouble finding how to change the sidelight bulbs on cars with xenon lights. Someone mentioned going in through the wheel arch, anyone shed some light?
v4rley
Just look at my post count
-Given: 29
-Receive: 104
Re: Changing sidelight bulbs on factory xenons?
Reply #1 on:
April 08, 2017, 06:43:30 pm »
No need to go through arch, can be done from the engine bay. Remove plastic cap on rear of the lights, pliers are handy as bit tight inside the unit
K9
-Given: 1
-Receive: 14
VW LifeStyle
Reply #2 on:
April 08, 2017, 07:32:05 pm »
or if you have small fingers like me, then you can just pop the covers off and pull it out gently.
r5gtt
-Given: 342
-Receive: 334
Reply #3 on:
April 08, 2017, 10:35:30 pm »
Don't know about gently as these buggers are sometimes jammed with the silly design of the side light cover which has a clip either side but can be done through the back cover as mentioned
Dale
Taking part
-Given: 3
-Receive: 3
Reply #4 on:
April 11, 2017, 01:29:02 am »
There is a cerated bit on the bulb holder, get a small screwdriver behind the cerated bit and pry it against the side of the light. You might want to use a finger on the other side and pull at the same time. Pops out easy.
lukemk5gti
-Given: 28
-Receive: 118
My Ride:
Reply #5 on:
April 11, 2017, 08:31:54 am »
I've a mini guide on the first page of my build thread
http://www.mk5golfgti.co.uk/forum/index.php/topic,89715.msg907250.html#msg907250
It's tough getting in there and the bulbs are press fittings so a needle nose pliers will be needed to pull them out.
All Things Mk5
Mk5 General Area
