Author Topic: Where to buy the NGK-BKR7EIX spark plugs today?  (Read 5853 times)
Offline fazi123
« on: April 24, 2017, 10:16:05 am »
Hi guys,
My cars got a misfire on bank 4, and I replaced the coil pack and it hasn't cured it. I can only assume it is the spark plug.
I'm interested in the NGK-BKR7EIX as they seem like what a lot of guys on here are running, but need to buy them today. I'm based in London - so somewhere close will be helpful :)
Thanks,
Faz
  • -Receive: 690
Re: Where to buy the NGK-BKR7EIX spark plugs today?
« Reply #1 on: April 24, 2017, 11:42:40 am »
More likely to be an injector than a spark plug.
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=ou877p83uj4jqd5h2emenp5f8p&/topic,19740.0.html
« Reply #2 on: April 24, 2017, 11:56:17 am »
Eurocarparts sell them
Offline fazi123
« Reply #3 on: April 24, 2017, 12:01:44 pm »
Do you have a part number Rich? I haven't been able to find them when putting my reg in :sad1:
Offline fazi123
« Reply #4 on: April 24, 2017, 12:04:00 pm »
What makes you think this? My symptoms are constant rough running when idle, and when trying to move. I've read another thread on here (I think it was @AJP thread) but his symptoms which were somewhat cured by refurbished injectors were seemingly different.
« Reply #5 on: April 24, 2017, 02:23:28 pm »
You wrote the part number in your first post... just ring your local branch up and see if they have them in.
  • -Receive: 690
« Reply #6 on: April 24, 2017, 02:28:11 pm »
Experience.
Offline AJP
  • -Given: 392
  • -Receive: 316
« Reply #7 on: April 25, 2017, 09:07:02 am »
Injector 4 rough idle. Quite common for some reason.
If you want some of those plugs I've got a new set I can send out, but not until the end of the week.
Offline fazi123
« Reply #8 on: April 25, 2017, 03:50:00 pm »
I managed to get a set of these NGK plugs yesterday afternoon :)
Pleased to say the roughness / misfire is completely cured. I've driven about 70 miles since the change and it's running sweet again :)
When doing the change, I did notice that spark plug number 4 (it was the one situated furthest right when looking under the bonnet) was burnt out. The other 3 still had some unburnt material on them so I'm hoping it was just this that was causing the lack of 'spark'/
Thanks for the offer @AJP - Much appreciated bud!
Thanks for your input on my issue guys :)
I'll be sure to update this thread if the misfire comes back anytime soon.
  • -Receive: 690
« Reply #9 on: April 25, 2017, 03:59:22 pm »
Post a pic of plug 4.  "Burnt out" doesn't sound very good at all!
Offline AJP
  • -Given: 392
  • -Receive: 316
« Reply #10 on: April 25, 2017, 06:35:56 pm »
Glad things seem better for now @fazi123
But... (and I agree with Pud that this warrants further investigation)
Why's the plug fouled? Is it orange?
A knackered plug might be a symptom of an issue rather than a cause. Definitely post up a pic.
If you've been going lean on 4 a new plug is not the fix.
Offline fazi123
« Reply #11 on: April 25, 2017, 08:34:30 pm »
Hi,
Please find pics to show what I meant by "Burnt out".
First 2 from the Drivers side of the engine - the tips are "cleaner".
Second 2 from the passenger side show the 4th one with a burnt out tip
Let me know if you guys think there's anything untoward aside from one of the spark plugs being effectively "dead".
Just to add these are ~18k miles old and were put in about 600 miles before I went to R-Tech for a stage 1 when I had completed a full service with cam belt & cam chain etc.
  • -Receive: 690
« Reply #12 on: April 26, 2017, 09:48:51 am »
Are they OEM plugs or aftermarket?
Number 4 is oil fouled, which is explains why it eventually gave up sparking.   I think that cylinder needs a compression test / inspection because it's burning quite a bit of oil.   Hope it's not a broken piston ring land.  Seems to be very common on the TFSI group these days, especially on Stage 2 and above cars.
Offline fazi123
« Reply #13 on: April 26, 2017, 10:31:18 am »
The current plugs are OEM or equivelant -
 http://www.eurocarparts.com/ecp/c/Volkswagen_Golf_2.0_2005/p/car-parts/regular-service/car-service-parts/spark-plugs/?408441120&1&2a6c66423494a27daa7f10ccbb786e12bfddf13c&000301
This is what the garage (Audi/VW specialist) fitted when doing my service just over a year ago.
Would I have any other symptoms for a broken piston ring? It drives absolutely spot on and has been absolutely perfect aside from the day the spark plug gave up.
  • -Receive: 690
« Reply #14 on: April 26, 2017, 10:58:41 am »
Might not be a cracked ring land then if it's driving OK, but worth compression checking cyl 4 and comparing to the other 3.  That cylinder is definitely burning more oil than the other 3 though.
