Author Topic: NEW - Neuspeed 2.0T K04 Hi-Flow Turbo Discharge Kit  (Read 14506 times)
Offline Janner_Sy
  • -Receive: 113
Re: NEW - Neuspeed 2.0T K04 Hi-Flow Turbo Discharge Kit
« Reply #15 on: February 01, 2010, 08:50:13 pm »
thing is carl there is 6 months between those two runs.
the difference could be due to the Discharge pipe, but could just as simply between different fuels, ecu adaption from when you first had your car set to revo stage 2, or just a difference in the dyno runs on different days (atmospheirc pressure, ambient temp, granted theyahve calcs to minimise difference) plusyou can chuck your car on the dyno and get 3 consecutive readings within 3-5hp of each other.
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
« Reply #16 on: February 01, 2010, 08:55:42 pm »
wow Carl , the torque peak looks to come in almost 250rpm earlier
although the plateau afterwards seems steeper ?
Red ED35 5dr DSG
BLOG | BUILD
Offline danishmkvgti
  • -Given: 243
  • -Receive: 155
« Reply #17 on: February 01, 2010, 08:58:48 pm »
done within 2 hours on same dyno, only difference is BN Autoteknik Turbo discharge pipe and turbo outlet on K04 APR software.
http://www.mk5golfgti.co.uk/forum/index.php?topic=10780.msg165147#msg165147
Over the top mod list ;o)
Offline vRS Carl
  • -Given: 282
  • -Receive: 241
« Reply #18 on: February 01, 2010, 09:08:11 pm »
Yeah it did come in a bit earlier Probably about 500rpm and The plateau dip is due to the wheels slipping slightly on the dyno (that's what Keith said due to the cold day.) the torque is higher from earlier on as well
At 2000rpm before the pipe was 180lb/ft
At 2000rpm after the pipe it was 210lb/ft
@Sy - The car is always run on V-Power and was on both those runs. The car had been on Stage 2 at that point for about 3 months so the ECU was well adapted. And as you well know from when i did the run in the second graph (as you were there) all four runs JKM did gave 256.x bhp (as the S3 cooler generally keeps the runs pretty consistent).
So maybe it could be difference elsewhere but i would be more inclined to believe (especially as i had a RR log done in the Nov in between iirc and that still gave 252bhp) it was the outlet pipe.
Carl :happy2:
« Last Edit: February 01, 2010, 09:12:23 pm by Mater »
Offline Janner_Sy
  • -Receive: 113
« Reply #19 on: February 01, 2010, 09:23:04 pm »
not disputing it, just stating that is a possibility.
i dont doubt they would work, just a quick look at the stock discharge piping you can see the the amount of restiction there and the improvments that could be made.
« Reply #20 on: February 01, 2010, 10:35:36 pm »
JBS sell it for £142 incl tax.
eurojet are knocking them out for $125 (£78) which is a big saving but doesnt take into account the delievery
ive never ordered from america before so if i was to buy that, would i get smashed with impot tax and delivery.
....The supplier in the US will charge you shipping but will probably give you a choice of how. Faster costs more.
The UK will possibly, increasingly probably, charge you both handling and taliban tax (vat). Because of increased anti-terrorist security measures much more gets checked nowadays. Oh, and the UK system could hold it up a couple of weeks although the more efficient US system might get it landed in the UK in just a couple of days!
Sorry - I'm just telling you the worst case but it's happened to me quite a few times and it's best to plan for the worst. It's a lottery.
« Reply #21 on: February 01, 2010, 11:34:44 pm »
Some great info guys :happy2:
Just to let you know, I've taken a punt for the Neuspeed version and will be getting before and after dyno plots too. :jumpmove:
The Neuspeed one has a larger bore than OEM and isn't "squashed" like the OEM one.
http://www.awesome-gti.co.uk/shopimages/products/extras/48.02.69_img2.jpg
Offline Janner_Sy
  • -Receive: 113
« Reply #22 on: February 01, 2010, 11:37:22 pm »
you not going to look  into the TB/IC pipe. alot of constriction in that pipe.
« Reply #23 on: February 01, 2010, 11:53:57 pm »
I have a Forge Twintercooler and only need the discharge pipe to mate up to it :happy2:
Offline vRS Carl
  • -Given: 282
  • -Receive: 241
« Reply #24 on: February 02, 2010, 07:48:48 am »
I have the Neuspeed version of that pipe Sy and it made no difference whatsoever to the output. I tried it when i was looking for the phantom stage 2+ problem and got the exact same Torque & Bhp as i did a month earlier.
I Still have it actually and might put it up for sale.
Carl :happy2:
Offline Janner_Sy
  • -Receive: 113
« Reply #25 on: February 02, 2010, 08:02:30 am »
the neuspeed one is still really constricted in comparison to the SFS and eurojet varients though.
Offline vRS Carl
  • -Given: 282
  • -Receive: 241
« Reply #26 on: February 02, 2010, 08:21:23 am »
How :confused:
Neuspeed
Eurojet (pretty much same shape)
SFS (link click on MKV turbo kit and its the top hose) again pretty much same shape
http://www.sfsperformance.co.uk/prod_carkits.asp?make=volkswagen
Carl :happy2:
Offline Janner_Sy
  • -Receive: 113
« Reply #27 on: February 02, 2010, 08:39:50 am »
lol, cancel my last then, the pic i saw looked remarkably similar to the stock pipe.
« Reply #28 on: February 02, 2010, 11:10:02 am »
I haven't looked into the detailed comparisons but whichever kit anyone goes for they should make sure that the last section attaching to the turbo is that special heat resistant hose (Nomex) or metal, and not standard silicone or plastic.
« Last Edit: February 02, 2010, 11:58:33 am by RedRobin »
