Author Topic: So.. Just saw this vid on youtube - working blind spot assist  (Read 5280 times)
Offline Christiank
  • -Receive: 39
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,110924.0.html
As the tittle says.
Check this guys Mk5 out .. Awesome retrofits done!  :congrats:
Btw.. If anyone know what he used to make this blind spot assist - Oh please do share! Since I really want to add this to my car.
Also want the chrome air vent frames! - So anyone?! :D
MK5 TDI 2.0 MY2005 - FULL OF RETROFITS:
MK6 dashboard - BCM converted - MK7 cruise control MFSW - PLA 2.0 - 3D instrument cluster - Discover Media 2 - Highline TPMS - 10ch Dynaudio system - KESSY with start button
Offline AJP
  • -Given: 392
  • -Receive: 316
Re: So.. Just saw this vid on youtube - working blind spot assist
« Reply #1 on: April 30, 2017, 08:13:57 pm »
Hmmm. Quite a cool feature, but I wouldn't want to get into the habit of relying solely on that rather than actually turning my head.
It'd be interesting to read what the manufacturers of cars factory-fitted with these say in the user manuals. Bet my balls it's something along the lines of "This is not a substitute for direct manual observation of the blind spot...".
Offline SI-R32
  • -Receive: 126
« Reply #2 on: May 01, 2017, 10:52:43 am »
just very quickly looking into this looks fairly easy to do, i thought it might use the side rear sensors form PLA 2 but the car would have to be literally on top of you, for once it looks like 2 simple control units fitted behind the rear bumper.
the wiring is simple, unit 1- power, can bus and local bus to unit 2.....unit 2 - power, local bus to unit 1 and power out to lights in the mirrors on either side of the car to show up when a car is approaching. here is one of the units found on ebay
http://www.ebay.co.uk/sch/i.html?_from=R40&_trksid=p2380057.m570.l1313.TR0.TRC0.H0.X5Q0907685A.TRS0&_nkw=5Q0907685A&_sacat=0
http://www.vwgolf.org/removing_and_installing_blind_spot_monitor_control_unit_j1086_j1087-2603.html
interesting next mod?
Offline doylebros
« Reply #3 on: May 01, 2017, 12:25:59 pm »
Very interesting and first I've seen for retrofitting for that mod.
Keep us all educated if anyone makes progress with it  :happy2:
Offline SI-R32
  • -Receive: 126
« Reply #4 on: May 01, 2017, 12:43:04 pm »
following up a little the can wires go to a new set of inputs on the latest mk7 gateway called "can extended high" we don't have this as far as i'm aware just yet pin 7 can low and pin 17 can high ? still looking further into it.
« Last Edit: June 14, 2017, 02:21:21 pm by SI-R32 »
Offline Christiank
  • -Receive: 39
« Reply #5 on: May 01, 2017, 07:03:32 pm »
Isn't it only audi and VW that has the MIB Pro and MMI seperated with screen and the hardware unit behind/in the glovebox that has the Can extended high?
Might be wrong here though. - Will keep searching for some info. This mod is added to the "to do" list hehe
I've got the 7N0 "AS" Canbus and a 3D Tiguan cluster fitted in my MK5 so this should be up to date.
**** A little more searching for this , and I found out that this feature is already fitted on the VW Phaeton 3D from around 2008. So guess I should work without the extended high can.   Or what do think about this? :) @SI-R32
« Last Edit: May 01, 2017, 08:10:37 pm by Christiank »
Offline Christiank
  • -Receive: 39
« Reply #6 on: May 10, 2017, 07:18:40 pm »
So who's going to retrofit this first? :D
Offline v4rley
  • -Receive: 104
« Reply #7 on: May 10, 2017, 07:26:23 pm »
My bet is it will be yourself @Christiank  :laugh:
Offline SI-R32
  • -Receive: 126
« Reply #8 on: May 10, 2017, 07:41:55 pm »
I've got hold of the sensors, plugs,yet another can gateway, my only problem is I don't have colour cluster, I'm hoping to be able to turn it on with adaptation in vcds, if not I'm a little screwed,.
Testing with temporary loom and bits when weather gets better.
One other thing I'm worried about is when enabling extended can on newer gateway this now deals with headlight level control, as I have factory xenons, I might get faults? So a lot to play with but that's part of the fun
Offline Christiank
  • -Receive: 39
« Reply #9 on: May 10, 2017, 07:46:26 pm »
Simon.. I thought you already was going on it :D
I also got factory Xenons on mine.. With 3D color cluster from Tiguan and newest 7N0 "AS" canbus.
Haven't got any faults on xenons.
So you can ship out the set to me for testing  :drinking:
Did you go with the mk7 golf set or the passat B7/8? the mk7 set is a whole lot cheaper than set for Passats..
Was thinking to buy this set
https://www.aliexpress.com/item/OEM-Original-Side-Assist-For-Volkswagen-VW-Passat-B7-2012-2013-CC-2013-3C8-857-538/2024014144.html?spm=2114.01010208.3.9.icB1mj&ws_ab_test=searchweb0_0,searchweb201602_2_10152_10065_10151_10068_436_10136_10137_10157_10060_10138_10155_10062_10156_10154_10056_10055_10054_10059_10099_10103_10102_10096_10147_10052_10053_10142_10107_10050_10051_10171_10084_10083_10080_10082_10081_10110_10111_10112_10113_10114_10181_10183_10182_10185_10078_10079_10073_10070_10123,searchweb201603_4,ppcSwitch_5&btsid=0cdf6395-a5f8-4345-9a75-922940344868&algo_expid=77e3f60c-9605-4628-89c0-f4105ed7344f-1&algo_pvid=77e3f60c-9605-4628-89c0-f4105ed7344f
But if it'll work with the mk7 set, that will be the way I'm going.. Only problem is the light that shows something is in the blind spot? The mk7 has it in the mirror glass and the Passat has it in the cover. - Which was also the main reason I think the Passat set would be the way to go.
« Last Edit: May 10, 2017, 07:52:42 pm by Christiank »
Offline v4rley
  • -Receive: 104
« Reply #10 on: May 10, 2017, 07:49:47 pm »
I'm happy to loan you some if it would assist  :happy2:
Offline SI-R32
  • -Receive: 126
« Reply #11 on: May 10, 2017, 07:52:48 pm »
I haven't got a kit, bought both sensors for £127, 2 plugs for £6 will make my own loom up and will fit leds to inside mirror trim, not the mirrors, don't know if the mk7 brackets fit behind the bumper so may just try another way of sticking them to mk5 bumper to save £30 on brackets
Offline SI-R32
  • -Receive: 126
« Reply #12 on: May 10, 2017, 07:54:27 pm »
Cheers, the only thing I might need is just to turn it on then swap cluster back to my scirocco one, but if I can do in adaptation I'll write it all up for others so see
Offline Christiank
  • -Receive: 39
« Reply #13 on: May 10, 2017, 07:55:05 pm »
Yeah allright mate :)
You can buy these to make it look right..
https://tr.aliexpress.com/item/OEM-Original-Side-Assist-Led-Light-for-Passat-B7-CC-Golf-6-Jetta-MK6-35D-949/32701502687.html
Offline SI-R32
  • -Receive: 126
« Reply #14 on: May 10, 2017, 07:57:54 pm »
Cheers Chris, not a bad price, I'll get some ordered see if I can fit them in somewhere.
