Author Topic: Rear Brake Disc Shield - remove and replace?  (Read 4061 times)
Offline blueislander80
« on: May 16, 2017, 01:15:45 pm »
Right, so the rear right brake disc shield is rotten, has sheared off and is making a hell of a noise - my local garage is going to hopefully cut it away and get it off tomorrow - not sure if that can be done just with some cutting or if bits and bobs need removing first?
Second question - I can't find anywhere that sells a replacement heat shield for the brakes? I also read it isn't really necessary to have them - is that right? I assume it basically deflects heat and protects from road debris?
Offline andy7ven
  • -Receive: 30
Re: Rear Brake Disc Shield - remove and replace?
« Reply #1 on: May 16, 2017, 04:38:49 pm »
You need to actually remove the brakes and wheel hub to remove them... Mine need replacing but I ain't wasting £££ on having it done to be honest...
TPS will have them, I don't think they're needed but might be wrong...
Offline strongbow
« Reply #2 on: May 16, 2017, 07:05:51 pm »
cant remember who but someone on the forum told me to cut them off with tin snips,cutting pieces away at a time,and adventually pulled off due to the rust,annoying noise solved and only replaced due to needing new rear bearing 2 years after.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #3 on: May 16, 2017, 11:16:28 pm »
On the subject and hope op doesn't mind?
Can I get dust shields for the bigger 350mm onward discs?
