Author Topic: Cost of a new front hub?  (Read 7414 times)
Offline ollie288
« on: February 02, 2010, 08:43:28 pm »
I had a right game on the way home from work, heard a wired knocking, grinding noise and the abs/tc lights came on. Pulled over and jacked up the passanger side and the whole wheel, brake caliper and pad and hub where wobbling!  :surprised:
Turns out the bolt that goes through the hub had worked its way loose. I tightened it back up but there is still movement in the wheel.
I think the hub has gone? Does anyone know the cost of a new one?
Ollie :happy2:
Offline gazbutS3
Re: Cost of a new front hub?
« Reply #1 on: February 02, 2010, 10:15:38 pm »
sounds like the wheel bearing has collapsed
« Reply #2 on: February 02, 2010, 10:17:17 pm »
 :surprised:
Good thing you stopped to investigate!
Offline ollie288
« Reply #3 on: February 02, 2010, 10:39:51 pm »
What would be required to fix this? Is it a case of removing the hub bit where the wheel bolts go in and replace it?
Cheers  :happy2:
:surprised:
I know! Im hoping nothing else is damaged!  :scared:
Offline xxx_mojo_xxx
  • MUBster DUBster
« Reply #4 on: February 02, 2010, 11:37:30 pm »
I had to have both of my front wheel bearings replaced - split 6 months apart.
Fortunately the repair work was covered under warranty.  If I remember correctly the VW service man rambling on about them costing £40 each.
P.S.  It's easier and safer to get the entire hub with the bearing...saves on a lot of time faffing around.
Offline ollie288
« Reply #5 on: February 03, 2010, 05:50:56 pm »
My car is still under warranty but it wont be covered as it has been changed!  :sad1:
I can still hear a funny noise coming from that side. Everything is tight. I think it is the wobble it still has. Is there any other damage I should be looking out for?
Im going into VW tomorrow to see the damage to the car and my pocket!  :mad:
Do you think I need to pay VW to fit it or just buy one and fit it?
Im starting to wish I would have sold it now!
« Reply #6 on: February 03, 2010, 10:12:23 pm »
if it is the wheel bearing that is causing the trouble-but the wheel bearing at the parts department and get your local specialist to fit it for half the labour costs
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #7 on: February 04, 2010, 07:18:28 am »
If it's the main bolt through the middle then that bolts into the drive shaft and not the hub, it only passes through the hub.
There is a specific torque setting for these bolts which can often be ignored when for instance fitting new suspension.  They are also once only, again often ignored.
I had both front hubs replaced on one of my Octavia's under warranty. (Turned out to be the tyres in the end but that's another story)
I'm fairly certain the hubs aren't too expensive at between £40-£50 which considering the size of the lump of metal isn't bad.
Stu...
Offline 08micsta
  • -Receive: 63
  • Smart Fortwo 600cc
« Reply #8 on: February 04, 2010, 08:00:43 am »
Not much use here unfortunately... But please change your sig Ollie... I flinch everytime I see it!  :scared: :grin:
No PAS. No ESP. No DSC. No TCS. No ABS. Just my right foot between me and oblivion. Oh - And a seatbelt.
Offline ollie288
« Reply #9 on: February 04, 2010, 07:09:04 pm »
Been to VW today
£100 for the ball bearing bit and £200 for the housing if I need it. Also the brake may have warped so could be more. Plus labour! To say I am annoyed is an understatement!  :fighting2:
« Last Edit: February 04, 2010, 07:41:03 pm by ollie288 »
Offline ollie288
« Reply #10 on: February 04, 2010, 07:11:39 pm »
Interesting,
Yes thats the bolt. It was tightened finger tight by accident. It was the same bolt reused.
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #11 on: February 05, 2010, 07:13:30 am »
Interesting,
I'm away at work at the moment so I don't have too much stuff with me but I'm pretty sure the front hub comes complete as a sealed unit with a bearing pressed in.  It's about a 30 min job to change.
Stu...
  • MUBster DUBster
« Reply #12 on: February 05, 2010, 09:23:00 am »
The hub comes with the bearing sealed in it, yes... try contacting SKF in Luton.  They actually manufacturer the things in Luton...
Offline ollie288
« Reply #13 on: February 05, 2010, 03:13:58 pm »
Cheers chaps.  :happy2:
I think he said it was the hub with the bearings inside and then there is a housing that that goes into.  :confused:
Do VW sell the bolt so I can get them changed when fitted again? Also the torque to which they are done up to?
Thanks :happy2:
Offline Norbreck21a
« Reply #14 on: February 05, 2010, 03:27:56 pm »
Ollie,
Think the part number is WHT 002 795 (dodecagonal head bolt M16 x 1.5 x 70)
According to Elsawin
12-point bolt, 70 Nm + 90° further  (Always renew after removing )
When bolt is loosened or tightened, vehicle must not be standing on its wheels
« Last Edit: February 05, 2010, 03:29:44 pm by Norbreck21a »
