Author Topic: Oil leak  (Read 8933 times)
Offline Stig_gti
Oil leak
« on: July 16, 2017, 05:39:41 pm »
Was under the car earlier today and found this leak. Thinks it's engine oil and idea where it could be coming from.
Also only seems to be leaking when the engine is running
Looked around abit and can't seem to find it.
Offline Stig_gti
Re: Oil leak
« Reply #1 on: July 17, 2017, 11:38:29 am »
Any ideas point me in the right direction
Offline Pesky jones
Re: Oil leak
« Reply #2 on: July 17, 2017, 11:44:38 am »
Where is the first photo taken?
Offline Stig_gti
Re: Oil leak
« Reply #3 on: July 17, 2017, 11:58:24 am »
Laying from under the front of car so under the engine.
Offline Pesky jones
Re: Oil leak
« Reply #4 on: July 17, 2017, 12:05:37 pm »
Hmm. if it only leaks whilst engine is running, is it possible to get it cleaned up, get it on some wheel ramps and watch for where the leak comes from?
Offline Stig_gti
Re: Oil leak
« Reply #5 on: July 17, 2017, 12:12:42 pm »
I think this is the best option.
Just hoping it's something simple to fix and not to costly, if I can't find the problem will get it in to a garage so they can investigate further.
Thanks for the help.
  • -Receive: 690
Re: Oil leak
« Reply #6 on: July 17, 2017, 04:17:14 pm »
Smell the oil.  If it really stinks, it's gear oil.   Engine oil is odourless usually.
Is it DSG or Manual?  It could be a rear main seal (engine) or an input shaft seal (gearbox).
Offline Stig_gti
Re: Oil leak
« Reply #7 on: July 17, 2017, 05:20:42 pm »
It's a dsg I think it's engine oil coz I toped up the other month and its low again.
But I'm sure it smelt fishy.
Offline Pesky jones
Re: Oil leak
« Reply #8 on: July 18, 2017, 12:47:46 am »
DSG fluid smells fishy. Like the glue in primary school if you remember it!
Offline Stig_gti
Re: Oil leak
« Reply #9 on: July 19, 2017, 09:37:22 am »
Car will be going in on Monday.
I've looked closer and seems to be rear main seal common problem on tsi engines.
Cause more then likely pcv valve failed and built up pressure causeing seal to leak.
Not happy it's a gearbox out job for a cheap part.
Offline Pesky jones
Re: Oil leak
« Reply #10 on: July 19, 2017, 10:17:10 am »
Can you let me know the cost, I have an oil leak that im not sure where is coming from as well - it gets onto the underside of the gearbox so I fear that it is the main seal as well. Only leaks when warm/driving
Offline Stig_gti
Re: Oil leak
« Reply #11 on: July 19, 2017, 01:40:41 pm »
Will do mate same issue as me as my cars garaged and no oil on the floor.
Got a rough price of £650 but he is looking Monday and will tally everything up.
