Snip
8J0 412 331, qty 2 - TT/RS3 rubber top mounts.
6N0 412 249D, qty 2 - Bearings. Yep, that is a Polo part number, but also lists for Audi....but not VW for some odd reason, they are the latest revision and work fine on MK5s.
N910 216 061, qty 2 Damper top nuts.
N101 277 07, qty 6 - Rubber mount securing bolts.
Plus the strut pinch bolt/nut, qty 2.
Driveshaft Bolt, qty 2. Or if your CV boots look ropey, they come in a CV boot replacement kit, so do those whilst you're there.
Snip
So finally called TPS and current prices are (without VAT and per individual part):
8J0 412 331, qty 2 - TT/RS3 rubber top mounts. - £30
6N0 412 249D, qty 2 - Bearings. £15.53
N910 216 01, qty 2 Damper top nuts. Part number was a little wrong £2.75
N101 277 07, qty 6 - Rubber mount securing bolts. £0.99
strut pinch bolt/nut, qty 2. £2.55 for nut and £1.31 for the bolt
Driveshaft Bolt, qty 2. £5.03
Thought I would list the prices just in case someone else was looking into the same thing and thanks again Pudding for the part number!
Total cost is £144.26 which does put it £30 over the cost of the ECS front kit from PSI, I'm over budget as it is
so it doesn't make this decision any easier!
Anyone out there with experience of the ECS Uprated top mount?
Thanks,
Molesy
