Author Topic: Cam timing  (Read 1240 times)
Offline 99hagued
Cam timing
« on: August 20, 2017, 02:22:58 pm »
Was playing with vcds last night and checked my camshaft adjustment values does this look ok or not. No fault codes and car runs fine but it look further out than others Iv seen on the net.
<img src='https://i.imgur.com/rVWFIpV.jpg' />
At ide
<img src='https://i.imgur.com/HndtcEi.jpg' />
Giving the throttle a tickle
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=068295b48tk0gvaha4gfaqgj43&/topic,19740.0.html
Re: Cam timing
« Reply #1 on: August 20, 2017, 03:47:00 pm »
Looks ok to me.
  • -Receive: 690
Re: Cam timing
« Reply #2 on: August 21, 2017, 04:16:59 pm »
It's close enough. Remember engines are analog and take time to respond and settle onto it's targets.
Check 093 as well, which is how far off the cam is from the expected angle. -1 to -3KW is normal.
Offline 99hagued
Re: Cam timing
« Reply #3 on: August 21, 2017, 07:58:17 pm »
093 is at -4kw
  • -Receive: 690
Re: Cam timing
« Reply #4 on: August 22, 2017, 08:22:00 am »
093 is at -4kw
That's OK.
Mine was at -1KW when I did the chain last year but has since drifted to -3KW.  The chain links have 'settled' in I expect.
