All Things Mk5 > Performance Modifications
KONI FSD damper/spring question!
Shoduchi:
Koni FSD match well with Eibach Pro-Kit springs. You can't get the Pro-Kits for GTI, just for 2.0 FSI, but they should still be better than the OEM springs.
Another good option is what Pudding said.
paul n:
--- Quote from: Pudding on August 29, 2017, 09:53:32 am ---You might be better off going for the RacingLine kit, or just their dampers if you don't want to lower it. Tried, tested and proven to improve the ride quality.
FSDs for GTIs and non-GTIs are apparently very different in ride quality, and if matched with aftermarket springs, you could be setting yourself up for disappointment.
--- End quote ---
already got the FSD dampers as i found them on special so just bought them!
thinking now i should have just saved up for ohlins! will probably just run them with the OEM springs for now and see how they go! replacing the drop links, ball joints etc should tighten things up a little as well.
best place to get tops mounts, ball joints, drop link etc?
Cheers Paul
pudding:
--- Quote from: paul n on August 30, 2017, 01:22:51 pm ---
--- End quote ---
Cheers Paul
--- End quote ---
Yeah I went for the Ohlins. I hope they live up to the hype! I have to say though, the Racingline kit exceeded my expectations and would suit the majority of people. I just wanted the next level in damping, so Ohlins it had to be.
Ball joint options are Passat B6 from the dealer as they're 5mm taller than GTI, so work well on mildly lowered cars. Or SuperPro ball joints for more camber, which AKS Tuning sell.
Top mounts, I would go TT from the dealer. 8J0 412 331 x 2 (rubber mount). 6N0 412 249D x 2 (bearings). N910 216 01 x 2 (damper nuts). N101 277 07 x 6 (Top mount bolts).
Replacement GTI ones can squeak over speed humps etc because the metal part of the mount moves too much with uprated suspension.
Drop links I wouldn't bother with unless worn out.
The other thing I would strongly recommend is a TyrolSport deadset kit, which AKS also sell.
paul n:
--- Quote from: Pudding on August 30, 2017, 01:40:45 pm ---
--- End quote ---
Cheers Paul
--- End quote ---
--- End quote ---
cheers for the info :) i might have to hold off on the deadset kit as it is £225! read up abit about it thou and sounds good.
so deffo main dealer for parts? looking at ebay for those part numbers i can get febi replacement parts at a good price. i generally avoid main dealer as prices seem steep! is it worth doing the top mounts at the back as well?
be very interested to see how you get on with the ohlins!
Cheers Paul
pudding:
--- Quote from: paul n on September 01, 2017, 10:34:21 am ---
--- End quote ---
Cheers Paul
--- End quote ---
--- End quote ---
Cheers Paul
--- End quote ---
Trust me, it's probably the best £225 you'll ever spend on a GTI!
The bolts and bearings, definitely, but the rubber mount you could probably go with Febi. Not as sturdy or made to the same standard as OEM, but it'll do the job.
Dealers make most of their money from parts and servicing...... it costs money to keep the lights on and pay staff etc etc......but it's the only way to get factory quality parts. Even dealers wince at some of the parts prices.....but it's all a deliberate game to get us into newer cars.
Anyway.....yeah I will report back on the Ohlins :happy2:
Navigation
[0] Message Index
[*] Previous page
Go to full version
