Author Topic: Engine / trans mount bolts  (Read 3886 times)
Offline Rigsby
  • -Given: 22
« on: September 09, 2017, 06:13:54 pm »
Replacing my engine and trans mounts soon.
Anyone reused the original bolts?
Anyone got part numbers for the bolts and price? Don't really want to buy some but if needed I will do so
Offline Christiank
  • -Receive: 39
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,110924.0.html
Re: Engine / trans mount bolts
« Reply #1 on: September 09, 2017, 07:01:02 pm »
They are single use only. When that's being said, you can still tighten the old bolts again.. I personally would never re-use any stretch bolts again.
MK5 TDI 2.0 MY2005 - FULL OF RETROFITS:
MK6 dashboard - BCM converted - MK7 cruise control MFSW - PLA 2.0 - 3D instrument cluster - Discover Media 2 - Highline TPMS - 10ch Dynaudio system - KESSY with start button
Offline mycarnowork
« Reply #2 on: September 09, 2017, 08:48:10 pm »
Just got some from a vw dealer for driver side. Less than £20 and they had in stock. If not in stock normally can get for next day. For the sake of £20 I would get the bolts and not risk the engine dropping.
I was looking at some posts on engine mount bolts yesterday and see some people do reuse them but I decided to just get new bolts. What would it cost you if they broke?
Offline Rigsby
  • -Given: 22
« Reply #3 on: September 09, 2017, 09:56:00 pm »
Yeah, think I will have to order a set for both
Offline Rigsby
  • -Given: 22
« Reply #4 on: September 10, 2017, 11:32:46 am »
Anyone know what size bolts they are?
Can't I just buy some non stretch bolts? Atleast then if I need to remove mounts at a later date I don't have to buy bolts again
  • -Receive: 690
« Reply #5 on: September 11, 2017, 09:44:43 am »
Why?  Seriously.....what is wrong with just driving to the dealer and buying the CORRECT bolts?!
Stretch bolts are used in high stress / high vibration areas of the car for a reason.  If you use plain bolts on the gearbox mount, they will either snap or back out.  Use the VW bolts please.
Offline Rigsby
  • -Given: 22
« Reply #6 on: September 11, 2017, 12:20:06 pm »
Calm down , I've ordered them from tps £75
what about ford /honda etc, do they use  stretch bolts? As I've changed few mounts in my time and this is the first I've heard of them being stretch bolts
« Last Edit: September 11, 2017, 12:32:58 pm by Rigsby »
  • -Receive: 690
« Reply #7 on: September 11, 2017, 01:54:38 pm »
German cars have used stretch bolts for decades.  I have no idea about Ford or Honda.  Is it just that you are tight, or just don't understand the point of stretch bolts?
Offline Rigsby
  • -Given: 22
« Reply #8 on: September 11, 2017, 02:44:30 pm »
Both , what about dogbone mount? Is that a stretch bolt?
