Author Topic: Engine noise....  (Read 9121 times)
Offline Lewo
Engine noise....
« on: September 14, 2017, 08:44:36 pm »
Any ideas what this could be?
Parked up after a 20 miles drive, 3 hrs later and there was a squeaky type noise from the left side looking from the front when I started the engine.
I didn't think about filming it then....it didn't sound good but no lights on the dash and I was 200 miles from home.
I am no mechanic.... :smiley:
Thanks in advance  :happy2:
Offline Lewo
Re: Engine noise....
« Reply #1 on: September 15, 2017, 11:46:35 am »
Any ideas folks?
Offline doylebros
  • -Receive: 310
« Reply #2 on: September 15, 2017, 03:39:43 pm »
Simply take the auxilary belt off and that will greatly assist in identifying the noise.
Offline Lewo
« Reply #3 on: September 15, 2017, 04:17:39 pm »
Is that easy enough to do?
Offline doylebros
  • -Receive: 310
« Reply #4 on: September 15, 2017, 04:23:07 pm »
Watch this and decided if you've got the ability and tools
https://m.youtube.com/watch?v=n3tzsT_sX2M
Offline Lewo
« Reply #5 on: September 17, 2017, 11:28:19 am »
Cheers, I'll need to get it looked at by a garage.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #6 on: September 18, 2017, 02:23:16 am »
I heard a Reno Clio 2.0 sport 53 reg do this and it was the cam roller that snapped and rattling about to break off as it snapped the cam cover.
Offline Lewo
« Reply #7 on: September 18, 2017, 10:04:13 pm »
Cambelt and water pump was done 18mths ago.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #8 on: September 19, 2017, 11:53:20 am »
Check them! Let's hope it's not that.
Also fan belt tensioner sounds like that when worn!.
Have you been to the garage yet?.
Did you say you were local?
Offline Lewo
« Reply #9 on: September 19, 2017, 08:00:07 pm »
I hope not too....
I'm waiting to hear if there's a garage (Kent) that's used to working on these engines so I can get a qualified opinion.
I might take it to a general garage tomorrow to see if they can identify the sound but I'm a bit uneasy using the car at the moment, just in case.....
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #10 on: September 19, 2017, 09:57:28 pm »
Ah that's annoying.. have you tried kwik fit halfrauds just to get the noise identified?. My local kwik fit was really helpful a few weeks back finding a damaged anti roll bar bracket but sadly couldn't do any work on it and I really had to replace the bracket to fix the problem in the end!.
Offline Lewo
« Reply #11 on: September 23, 2017, 01:25:29 pm »
UPDATE
Mate did a VCDS scan yesterday just for some piece of mind no codes came up.  :happy2:
Took wheel and cover off, that is the extent of my knowledge done now  :smiley:
Any more clues from the clips? Seems to be from that bottom pulley area.
Offline 99hagued
« Reply #12 on: September 23, 2017, 10:32:28 pm »
I would be taking the aux belt off mate and try running it
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #13 on: September 24, 2017, 02:05:04 am »
Either the AC pump or tensioner roller  :popcornsoda:
Offline mycarnowork
