Author Topic: airbag loom to airbag connection  (Read 2965 times)
Offline shoaybmakda
  • -Receive: 54
« on: September 20, 2017, 10:55:08 pm »
hi
just recently bought a mk6 airbag to go with my wheel but not sure where the pins go on the airbag to connect it up.
anyone have any pics or guides on how to connect the loom to the airbag?
thanks
Offline shoaybmakda
  • -Receive: 54
Re: airbag loom to airbag connection
« Reply #1 on: September 21, 2017, 11:05:19 pm »
anyone?
Offline SI-R32
  • -Receive: 126
« Reply #2 on: September 22, 2017, 10:16:44 am »
its the only pic i have, hope it helps
Offline shoaybmakda
  • -Receive: 54
« Reply #3 on: September 22, 2017, 04:02:17 pm »
@SI-R32 thanks for that I can just about make it out which helps
Can any of the pins go onto where the hooks are? I’m just worried about blowing they airbag once the battery goes on!
Offline Kai96
« Reply #4 on: September 22, 2017, 05:00:51 pm »
When I did mine I put the pins anywhere on the hooks and it's been fine ever since so I'm guessing so !
Sent from my SM-G930F using Tapatalk
Offline shoaybmakda
  • -Receive: 54
« Reply #5 on: September 22, 2017, 07:49:48 pm »
@Kai96 just don’t want the airbag blowing in my face when I reconnect the battery! Lol
Offline Kai96
« Reply #6 on: September 22, 2017, 08:45:06 pm »
Shouldn't do I remember just plugging mine into any didn't even think about them having a specific placement . Let us know how you get on
Offline shoaybmakda
  • -Receive: 54
« Reply #7 on: September 23, 2017, 11:15:42 pm »
@Kai96 fitted it today - looks and feels much better!
No blown airbag thankfully!
Cruise control not working however - not getting picked up reckon might be a dodgy stalk. Horn out of action too..
Offline Kai96
« Reply #8 on: September 24, 2017, 01:31:50 am »
When I first fitted mine it was the same the horn wasn't working but once somebody coded it all it started working again, and I've read somewhere if you switch to the mK6 steering wheel you might have to change the cruise stalk depending on which one you have at the moment
Offline shoaybmakda
  • -Receive: 54
« Reply #9 on: September 24, 2017, 07:55:58 am »
Didn’t know I had to recode the horn - I’ll have a look
Yeah I fitted a rev G stalk but it’s come from China so I think might be a dodgy one.
Getting this error on VCDS
http://wiki.ross-tech.com/wiki/index.php/00895
Offline SI-R32
  • -Receive: 126
« Reply #10 on: September 24, 2017, 10:34:59 am »
Guessing you're using the ch module?
Are you coding up the wheel with 5-8 lin 2 as this is mk6 NOT 1-4 lin 1.3?
Cruise is coded number 3 in its correct position, not 1 or 0?
Offline shoaybmakda
  • -Receive: 54
« Reply #11 on: September 24, 2017, 11:18:42 pm »
@SI-R32 yep it’s a CH Module.
I think I might have coded it wrong now you mention it..I don’t think I put any numbers between 5-8 I’ll have a check tomorrow to see what I’ve done.
Mines a DSG with cruise installed via blinker stalk so I think I need to have my coding set to 0001834 as per what’s shown in the bubble in this link
http://www.mk5golfgti.co.uk/forum/index.php/topic,111328.15.html
« Last Edit: September 24, 2017, 11:30:47 pm by shoaybmakda »
Offline shoaybmakda
  • -Receive: 54
« Reply #12 on: September 25, 2017, 09:08:42 pm »
Had a look and it did have an 8 in there for multi function with Tiptronic and push to talk installed.
Put the code in and now I get the following which suggests to me the stalk may be buggered:
http://wiki.ross-tech.com/wiki/index.php/16952/P0568/001384
Offline shoaybmakda
  • -Receive: 54
« Reply #13 on: October 01, 2017, 11:07:46 pm »
got the cruise working!
just the horn to sort out but that might be due to where the pins are placed on the airbag?
