All Things Mk5 > Performance Modifications
Which engine code?
<< < (3/3)
GitFlog:
--- Quote from: colesey on June 07, 2018, 05:38:12 pm ---Note 1 refers to larger turbo for ed30 / byd etc
--- End quote ---
Note 1 sorry if i am being dumb not to sure what you mean
pudding:
From the site mate......
169 kW (230 PS), 300 Nm from 2,250 to 5,200 rpm (Edition 30, Pirelli)
BYD *1
*1 these versions have stronger pistons pins and new rings, reinforced connecting rods, new bearings, reinforced cylinder block at the main-bearing pedestals and cap, new, lightweight aluminium-silicon alloy cylinder head for high temperature resistance and strength, adjusted exhaust camshaft timing, increased cross-section high-pressure injectors, 1.2 bar boost pressure turbocharger with larger turbine and compression rotor.
The only thing I would question there is the boost pressure.  I don't think BYDs run 1.2 bar.  Closer to 0.9 - 1 bar.
Shoduchi:
--- Quote from: Pudding on June 08, 2018, 11:06:37 am ---From the site mate......
BYD *1
--- End quote ---
The BYD run with 1.2 bar of peak boost and 0,9 bar of stable boost on stock file. :smiley:
pudding:
Ah OK, thanks mate, I wasn't sure if VW quoted a spike or a held pressure  :happy2:
GitFlog:
ok thanks i just didnt see any mention of ko4, but now i understand thanks
Navigation
[0] Message Index
[*] Previous page
Go to full version
