First impressions after 100 km: A lot of problems:
1. Excepting the fact that the spigot is not sticking out enough to mount the wheel on and i made a custom piece on CNC machine, like an extension of the spigot.
2. At speeds beyond 50 km/h if i press the brake pedal the car starts to vibrate very powerfull, it is like the disc was deformed. The steering wheel vibrates very strong, the car vibrates.
3. When i steer left at maximum something is rubbing at my left wheel. When i steer right at maximum there is no rubbing. I sounds like metal on metal
![scared :scared:](https://www.mk5golfgti.co.uk/forum/Smileys/newsmileys/scared.gif)
4. The brake pedal feedback is very low, i have to push it very well for the brake to actionate
What i think that is the reasons are:
1. The vibrations could be from the custom piece. In the brake kit it was included a set of bolts longer than the normal ones. Could it be that there are strong enough to hold the wheel without the custom piece to be fitted? Could the bolts be forged?
2. A fabrication fault of the brake discs
I attached some pictures of the spigot with the OEM disc mounted, a picture of the spigot with the VWR disc, 2 picture with the custom made piece
