Today i went to another service and did the perfect bleed of the calipers. All the services didn't knew that you had to do the bleed on the both sides of the calipers. And that's the cause of the wobbling. Because the caliper wasn;t pushing with the same pressure on the both sides of the disc. I still feel a little vibration, but i will wait to see if it dissapears after some bedding.
The mechanic here told me that is possible that the discs were deformed because of the not-equal pressure pushed on the by the caliper. If this is true, i will buy another set of discs from VWR.
Another thing, about the pedal feel. After this perfect bleeding the pedal response is very prompt. I hit the steering wheel with my head after the braking :))
