Author Topic: Highline comp  (Read 4116 times)
Offline Truckie
    • Formula Hot Laps
Highline comp
« on: February 11, 2010, 02:48:29 pm »
I currently have the pikey midline comp in my edition 30. Can anyone tell me how much roughly to change to the highline, also is it an easy task, how much do you have to change?
Cheers, craig.
Re: Highline comp
« Reply #1 on: February 11, 2010, 02:59:37 pm »
I remember one of the other forumites got this done. The highline itself wasn't much but the labour killed it - to have things like mileage etc transferred over, you need to have it done by VW themselves. Or so I'm lead to believe.
Re: Highline comp
« Reply #2 on: February 11, 2010, 03:17:28 pm »
I had highline installed.
the unit cost a lot the labour was half an hours. its so quick and easy for a good VW mech to do.
My car was that new that i couldnt put an older unit into my car without using VW.
i believe shark performance now have the gear to be able to do this
Re: Highline comp
« Reply #3 on: February 11, 2010, 03:18:13 pm »
the unit cost a lot the labour was half an hours. its so quick and easy for a good VW mech to do. its literally two screws and your done. then you need to code it.
Re: Highline comp
« Reply #4 on: February 11, 2010, 03:26:00 pm »
Thought it was you! But wasn't sure whether it was the labour or the unit that was expensive.
Re: Highline comp
« Reply #5 on: February 11, 2010, 03:28:32 pm »
i bought a brand new unit from VW. i spent £470 quid on it, but i did it in a way whereas if it was the wrong unit, VW were liable for ordering the wrong part.
at the time, 1 year ago, it wasnt well documented about which units work and which dont!
Offline danishmkvgti
  • -Given: 243
  • -Receive: 154
Re: Highline comp
« Reply #6 on: February 11, 2010, 03:43:34 pm »
i have an 06 model, the easy one, bought the highline module used for 200£, and 1/2 hour in labour.  :laugh:
Over the top mod list ;o)
Offline mortygttdi
  • -Receive: 146
Re: Highline comp
« Reply #7 on: February 11, 2010, 04:06:17 pm »
Cost me £60 for the r32 clocks and I didn't charge myself :grin:
Darren
Offline Norbreck21a
Re: Highline comp
« Reply #8 on: February 11, 2010, 04:06:34 pm »
Also recently had it fitted as well. Total cost £340.00.
A lot of money for what it is, but like others on here, I wanted it, so I did it.
As JPC said the problem is with the immobilsers and transfer of the mileage etc from one cluster to the other. You need the SKC (secret key code) to be able to do this. Darren has VAG Commander, which can read this code, but only upto (I believe 2006 model years). After that date, VAG changed the details on the clusters and after market software can't read the newer clusters, only the dealers (on in my case an independent) with the VAS tablet.
Andrew
Offline Lyons
  • -Given: 18
Re: Highline comp
« Reply #9 on: February 11, 2010, 05:09:48 pm »
Yup, my local dealer was loking around 340 fitted too.
Ill probably get it done st some point, just for RNS purposes.
Offline vRStu
  • -Given: 90
  • -Receive: 159
Re: Highline comp
« Reply #10 on: February 11, 2010, 08:03:23 pm »
As above Ben at Sharkperformance has the correct equipment to read all the clusters including the newer ones (VAG Commander)
Stu...
Offline Truckie
    • Formula Hot Laps
Re: Highline comp
« Reply #11 on: February 11, 2010, 09:22:28 pm »
Thanks for the info guys  :happy2: Another stupid question lol....i dont have mfsw, is that an issue? :ashamed:
  • -Given: 243
  • -Receive: 154
Re: Highline comp
« Reply #12 on: February 11, 2010, 09:33:49 pm »
No, but you will  want them after you have fitted highline, the mod itch won't stop  :rolleye:  :driver:
Offline Truckie
    • Formula Hot Laps
Re: Highline comp
« Reply #13 on: February 11, 2010, 09:37:01 pm »
Haha, dont i know it! How do you scroll through the options on the highline if you dont have the mfsw, thats what i meant to say lol!  :chicken:
  • -Given: 243
  • -Receive: 154
Re: Highline comp
« Reply #14 on: February 11, 2010, 09:42:18 pm »
the right stalk, wiper stalk in dk, not sure you have the same  :happy2:
