Author Topic: G269 fault code  (Read 3333 times)
Offline Neiltdi
  • Full Hex+CAN
G269 fault code
« on: February 21, 2019, 09:09:22 pm »
Hi guys long time!
I have a 2008 edition 30, it had standard shocks and springs with eibach lowering springs I replaced all shocks and springs with genuine parts now the orange steering light is on with fault code g269, I have tried doing the basic settings with vag com, light goes out drive and it’s perfect, turn engine off cycle ignition and light comes back on ?
Surely the rack hasn’t buggered from doing this job ?
Any help would be great !
Full Hex+CAN in Hampshire.
willni
Re: G269 fault code
« Reply #1 on: February 21, 2019, 09:52:55 pm »
If you have access to VCDs I'd follow Ross-Techs advice before doing anything else.
00573 - Steering Torque Sensor (G269)
00573 - Steering Torque Sensor (G269): Implausible Signal
Possible Symptoms
Steering Assist not working
Possible Causes
Steering Assist Power Supply (Terminal 15) faulty
Wiring/Connectors from/to Steering Torque Sensor (G269) faulty
Possible Solutions
Check Steering Assist Power Supply (Terminal 15)
Check Fuse(s)
Check Wiring/Connectors from/to Steering Torque Sensor (G269)
Check Steering Torque Sensor (G269)
Special Notes
When found in VW Golf (1K) Steering Assist (and similar), check Steering Torque Sensor (G269)
Checking Steering Torque Sensor (G269)
Prerequisites:
Ignition ON
Engine ON (Idle)
System voltage at least 11.0 V.
[Select]
[44 - Steering Assist]
[Meas. Blocks - 08]
Group 001
[Go!]
Field 2: Steering Torque Sensor (G269)
Turn the Steering Wheel multiple times completely to the left and right. The Torque Values should change.
If the Torque Values do change, it's most likely an intermittent Fault in the Wiring/Connectors.
If the Torque Values do NOT change, the Sensor itself or the Power Supply (Terminal 15) might be faulty.
Group 004
[Go!]
Field 2: Power Supply (Terminal 15), Specification: "Term. 15 ON"
[Done, Go Back]
[Close Controller, Go Back - 06]
Offline MIJ_JAGGER
  • -Given: 103
  • -Receive: 78
Re: G269 fault code
« Reply #2 on: February 22, 2019, 12:37:07 am »
Happened on mine, it’s the rack
